How can I take apart the Perfect Temp Drawer itself?
Model numbers are found on the inside wall of the fresh food compartment around the door or on the back of your refrigerator. What is your model number?
Appliance 911
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
SOURCE: crisper drawer freezes veggies
need more info what brand model and is it a side by side or top mount ? more info will be helpful
SOURCE: Vegetables in crisper drawer are freezing
you have to close vent completly with fridge gum or strong tape to solve this problem :)
SOURCE: Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
