Question about Canon MP-25DV Calculator
Setting Tax rate
How do I set the tax rate on my Canon MP-25DV calculator?
Posted by IM2Silly on
  • 4 more comments
  • Mi35 Oct 01, 2008
    Don't see a rate button on my calculator to be able to set the tax rate. Tanks
  • Anonymous Oct 14, 2008
    I don' t see a rate button. I have a slider under GT that says
    off, on, rate, then under that I have a button that says GT and to the
    right is the tax+ and tax- button. Thank you for your help.
  • Anonymous Mar 14, 2014
    change the ribbon spool on a canon mp 25dv
  • Anonymous Mar 20, 2014
    how to set tax on canon LS-85H calculator
  • Anonymous Mar 21, 2014
    the tax rate on my calculator is not correct I need to change it back to 15%
  • Anonymous Mar 30, 2014
    can't set calendar feature
Anonymous
Thank you for your suggestion.... I still don't see a rate button on my calculator. I have a GT sliding button that says off, on, rate. Under that I have a GT button, then to the right of that is the Tax+ and tax- button. I have set the tax a long time ago but can't find the manual to do it again. I really appreciate your help.
Posted on Oct 14, 2008
Anonymous
First, you have to make sure the calculator is set to two decimals. Then push the tax+ button, push the rate button. Now push the rate you want the tax ON, then push the rate button. If you want 2%, make sure to set the rate at 2, not at .02
Anonymous
Push the Tax + button
Push the Rate button
Put in the rate you would like to set
Posted on Jan 22, 2008
P23-DHV Calculator: setting 9% sales tax????...
The on switch has rate set, set your rate there. Hope this helps!!!
May 16, 2010 | Canon P23-DHV Calculator
How do I set the tax rate on LS-80TS?
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
Oct 06, 2009 | Canon LS-100TS Calculator
How do I program the calculator tax+ Tax- buttons?
1. How to set/ change "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator,
1. Press [AC] and hold [%] for about two seconds.
2. Input Tax Rate and then [%].
* You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator,
2. Input [TAX+].
3. Input Tax Rate and then [%].
2. How to calculate Price-plus-Tax and Price-less-Tax.
(1) How much is Price-plus-Tax of 100?
Press [AC], and input 100 and then press [TAX+].
Calculator will display 105 if tax rate is 5%
If you press [Tax+] again, it will show the tax amount..
(2) How much is the Price-less-Tax of 105?
Press [AC], and input 105 and the press [TAX-].
Calculator will display 100 if tax rate is 5%
If you press [Tax-] again, it will show the tax amount..
Jul 29, 2009 | Canon LS-100TS Calculator
TRYING TO SET THE TAX RATE ON MY CANON LS-120TS
just press tax till it blinks and then set the tax amount and then press tax button again
Jul 13, 2009 | Canon Office Equipment & Supplies
Lost manual
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
Dec 19, 2008 | Canon MP-25DV Calculator
Tax button
under the GT button at the top, switch that button to the "Rate"..enter whatever % tax rate you want. Then move button back to off setting.
enter your number and hit the plus sign, then the tax+ button or the tax- button. it will automatically figure the tax for you. You may have to play with it a bit..I got the pdf version from the canon tech geeks, and the directions leave lots to be desired. Good Luck!
Oct 31, 2008 | Canon MP-25DV Calculator
Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
Jul 30, 2008 | Canon P170-DH Calculator
Setting the tax rate on Canon MP25DV
the rate button is the 2nd slide switch from the right.. just above the GT key.
Apr 18, 2008 | Canon MP-25DV Calculator
How Do You Set The Tax Rate?
Turn the switch to Rate/Set, then click Tax+ then punch the number then turn the switch to ON. You are set for your tax.
Mar 17, 2008 | Canon P23-DH Calculator
Tax rate
Dec 10, 2007 | Canon MP-25DV Calculator
Canon MP-25DV Calculator Logo
769 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
