Computers & Internet Logo
What is the IP address for my Firestick? - Computers & Internet
Posted by KATHY Reed on
sandrasteven
    Master:
  • 875 Answers
Internal IP:that is assigned by your local network router and can only be seen by other computers in your local network and not by any computers connected in an external network The external IP is the one through which one gets connected to the internet.The External IP is got from the ISP and is classified into static and dynamic where static IP does not tend to change and the dynamic IP varies each time the modem is switched ON and OFF.If you have a dynamic IP then there are chances every-time you log on to the internet you are assigned a new IP.The duration to the change in IP depends on your ISP.If all your computers share the same modem with a static IP then there will be no change in IP address;if you use a dynamic one then each computer will have a different public IP address.You can check this through IP-details.com which displays your public IP when you visit the site.
Posted on Jan 25, 2016
Terry Hair
  • Computers & ... Master
  • 4,134 Answers
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Posted on Jan 02, 2016
Hello! The VPN I used for Firestick stopped working for me. Do you have any suggestions and recommendations on good services?
Hi there! There is a really good VPN solution for Firestick on https://www.firesticktricks.com/hide-ip-address.html and I think you will like it a lot too, have a look. Hope I was helpful to you here ;)
Do i need a vpn if streaming on a firestick or when using alexa
No you don not ,Amazon uses your IP address to allow fire to connect. No connection no service.
When I click on Droid Buddy, I get this: Not Found - The requested URL /apk/Droid_buddy_2.0.0.apk was not found on this server. I am installing on Firestick 2. Using downloader.
You should use a search engine to look for the /apk/droid_buddy_2/0.0.apk, there are a lot of them, just be wary of malware.
2answers
IP address for my firestick disappeared and firestick won't turn on. was working last night.
Perform one or more of
1. re-insert the firestick.
2. Power cycle the TV
3. renew the lease from the router (if not dynamic dhcp)
4. power cycle the router (as last resort)
Will not connect with BT hub type 5
https://s3-us-west-2.amazonaws.com/customerdocumentation/Fire+TV+Stick+User+Guide.pdf
Page 35
You may need to assign an ip address to the firestick and a Wep or WPA password that the Bt hub is requiring.
http://bt.custhelp.com/app/answers/detail/a_id/11383/c/346,1887
If you decide to go with a static ip address for the stick make sure it is not leased out and assigned by the bt hub DCHP server
3answers
My connection keep failing my password is correct.they are asking for my ip address where do i find that,
dont give anyone your ip adress,contact your internet provider to fix problem,if you are using someone elses wifi you will have that problem,use your own
1helpful
2answers
What is the ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.
There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address.
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
3answers
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
Marvin
Marvin
