2003 Mercury Marauder will not start with key ?
What exactly do you mean by 'Will not start'? Does it do nothing at all? Does it crank very slowly? Does it 'Clunk' then do nothing? Comment below with more information and I'll see if I can help more.
Get the starter motor and its wiring connectors Re-checked you do sometimes get 'Dud' car parts even when new. I had a brand new wheel bearing that lasted 140 miles then collapsed.
Bump starting doesn't use the starter motor at all to turn the engine. Bumping is where you start the vehicle using a 'back to front' method. Bumping in gear turns the wheels, which turns the transmission, which turns the flywheel, turning the crank to start the engine missing the starter motor out altogether.
