Mitsubishi Lancer 08 2008 Logo
M
Mike Posted on Jan 01, 2016
Where is the ignition coil located? - Mitsubishi Lancer 08 2008
1helpful
2answers
2005 Pontiac vibe fuse for coil . were is it located at
no fuse for coil if no power to coil[s] assuming its the ignition coils sheck and test wiring and coil for damage or failure
1helpful
Location of ignition coil relay 1992 gmc g2500 vandura 350
Location of ignition coil relay ??????? Doesn't have a relay for ignition coil . Power for it comes from the ignition switch.
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Where are the coil packs located on an 04 Lincoln LS v8? I have traced the wires from the spark plugs, but cannot see where they lead...
This is for the 3.0L engine:
3.0L Engine
  1. Remove the engine appearance cover.
  2. To access the right bank ignition coils, remove the upper intake manifold..
  3. Disconnect the electrical connector from the ignition coils.
  4. Remove the bolts.
  5. Remove the ignition coils.
To install:
  1. Replace the ignition coils.
  2. Connect the electrical connector to the ignition coils.
  3. Remove the upper intake manifold for the right bank ignition coils.
  4. Replace the engine appearance cover.
2answers
Where is the ignition module located on 2004 honda civic lx
I searched under 'ignition module' on autozone.com and 'no parts for ignition module' turned up.
I looked under DIS or Distributorless Ignition System and found the coils are inserted in the top of the engine and this tells me that it's likely that the ECM or PCM controls the spark on these cars.
Civic
1.7L Engine
  1. Disconnect the negative battery cable.
  2. Remove the ignition coil cover (A), disconnect the ignition coil connectors (B), then remove the ignition coils (C).
  3. Installation of the ignition coils is the reverse of the removal procedure.
    Fig. Remove the ignition coil cover (A), disconnect the ignition coil connectors (B), then remove the ignition coils (C)
1helpful
3answers
I cannot find my ignition module
Your ignition control module is under the coil packs on the motor.
Can't find location of all six spark plugs
The plugs are located below the 6 ignition coils. The three front ignition coils are located underneath the plastic engine cover that has the V6 3000 marking on it. The other three coils are located in the same position, in the other engine head, towards the rear of the engine compartment. They don't have a cover over them. You will have to unbolt and unplug each ignition coils to remove it.
1helpful
Where are the ignition coils located?
2helpful
2answers
How do i put a coil in a 2001 jaguar s type
303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual DESCRIPTION AND OPERATION Engine Ignition The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L 2001 Lincoln LS Workshop Manual
v-8
REMOVAL AND INSTALLATION Ignition Coil Removal
  1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
  1. Remove the bolts and the ignition coil cover.
  1. Disconnect the electrical connector from each ignition coil.
  1. Remove the ignition coils.
    1. Remove the bolts.
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual
  1. To access the RH bank ignition coils, remove the upper intake manifold. For additional information, refer to Section 303-01A .
  1. Disconnect the electrical connector from the ignition coils.
please rate as fixed if this helps.
Ignition coil location
Follow the plug wires back to the coil. This engine does not use "coil on plug" so there is only one coil. If there is a cover on top of the engine, most likely it's under the cover.
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
john h
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
