Yes you can provided your TV has the compatible connections available with the sound bar. If you buy a sound bar with a digital optical audio connection you will need the same connection available on your TV. So check the available connections on your TV before you buy.
HDMI vs optical Which digital audio connection to use CNET
SOURCE: I have sound but not picture on a Haier plasma tv
Hi my name is Roety,
I can help you with your issue ,
These Haier TVs go bad and I always install the repair kit part #?TV-3940-01
It includes the scan boards and an upgraded IC .
I can not find any kits in stock, but I know there some available online if you search or call a few places.
Mat electronics or sears parts direct may have some.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Testimonial: "this is very helpful,I will try it and let you know. NAVARRO"
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
SOURCE: digihome dvd not working
If it's a burned DVD or a CD, it might just be incompatible. Not every disc will work in the kind of older drives Digihome uses.
SOURCE: i have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
