Question about Water Heaters
Why no power to pump? - Water Heaters
Claude Kayser
    Top Expert:
  • Water Heaters Master
  • 9,098 Answers
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Posted on Jan 02, 2016
What causes my ferolli f24 to cut out when put on manual heating why does my ferolli f24 combi boiler cut out after putting on manual heating mode?
Possible that the pump is faulty, check to see if it is running, if not check power to pump, if power is okay, and the pump is not running, then it's the pump. look up pdf fault finding f24 for additional help.
Nov 23, 2014 | Water Heaters
There is no power going to the pump in my boiler
Power to the pump goes via the room stat in turn from the programmer check these out first
Apr 22, 2013 | Water Heaters
Install problems ge hybrid water heater
1) Copy following links for detailed resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
2) T2 is tank temperature sensor failure located just above upper element.
Call for service/ warranty.
Call GE 888-433-4394
3) Was water heater completely full of water before applying power.
Do you have 10 gauge wire and 30 amp breaker.
Is unit receiving 208-240 Volt power. Click breaker fully on-off.
Move wire to another same size circuit breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 03, 2013 | General Electric Ge Appliances GEH50DNSRSA...
Washer does not drain
1.), Pump may be bad. Check voltage to water pump in Spin Cycle. If you have voltage at the pump, but it does not run, replace the pump.
2.) If you have voltage to the water pump, and can hear or feel it running, cut power off, and remove the boot which is directly below the wash bin. The boot empties into the water pump. You will need long needle nose pliers or better, use water pump pliers to remove the straps holding the rubber piping to the pump and the boot. Remove debris from the boot, i.e., bobby pins, coins, socks, pens, keys, etc.
3.) If no voltage comes to the pump in spin cycle, you may need a new timer.
4.) Install a new belt on the motor pulley. You will regret not replacing the belt later.
Feb 02, 2013 | Whirlpool Whirpool 3.5cu ft Top Load...
Well x trol
check the circuit breaker then check the pressure switch if they are good then check the wires to the pump on top of the well head if you have power there then pull the pump check the wiring then the pump
Mar 28, 2012 | Water Heaters
Laing model 330 Pump not working-delay in hot water delivery.In the past,a vibration occurred when cold water running above the pump.Can this be repaired.Power operating to pump. Thanks, mel ross
Question not 100% clear.
1) The pump is not working? Does the pump make a noise? if pump is not working full-time, it can cause delay in arrival.
If pump motor is suspect, and outlet has power, then check override switch located on timer. Set override to Timer, move some of the trippers outward, then manually rotate timer dial until pump turns ON.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
If no noise is detected, or noise stops and starts, or seems strained, or if pump is hot, then pump motor may have burned out.
2) If pump is working, and makes noise like a humming sound, and pump motor is not hot, but hot water is not circulating, then unplug pump so it will not overheat and burn up.
Disassemble the pump and cross-over piece. Clean piping with white vinegar or CLR. Do not soak in CLR or it will damage seals. Rinse parts thoroughly. Reassemble and see if problem is resolved.
If pump is vibrating, then suspects include sediment and/or air inside line, and this can be resolved by cleaning as described. Also install air vent to increase life of pump.
3) Other causes for hot water delay at faucet are crossover.
Crossover can be caused by bad single-handled faucet cartridge, and/or by clogged-or-failed check valve on cross-over piece on grundfos.
This type of problem lets cold water enter hot line, and causes delay in arrival of hot water. Clean-or-replace the grundfos cross-over piece, and replace bad faucet cartridge.
Open following link for testing instructions:
http://waterheatertimer.org/Crossover.html
Resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/pdf/Troubleshoot-recirculation.pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 17, 2011 | Laing Thermotech Autocirc Undersink...
Resources:
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
My alpha cb24x combi boiler keeps blowing the main fuse,even when its not on,this can happen in 2mins or 2 days after i redo the fuse using 15 amp wire, why is this happening ?
a short circuit most likely on the pump or another winding, fan or gas valve. start with shutting off the power and pocketing the fuse untill ur done . dissconnect the pump supply and fit terminal blocks to make them safe. then turn the power on , but do not let the boiler run on either water or heating . let it sit for a spell and if the fuse does not blow simply replace the head of the pump, which is easier than replacing the complete pump. remember yuor not allowed to touch the gas train.
Apr 26, 2009 | Water Heaters
Water Heaters Logo
218 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
