Question about Samsung Televison & Video
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
Posted by Robin Marsh on
Lawrence Oravetz
  • Samsung Master
  • 10,548 Answers
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Jan 01, 2016
raider01
  • 6 Answers
Only sound but no display on Samsung SyncMaster MW series TV/Monitor set it's most likely caused by the inverter transformer failure: on the MW-932 check it on the power board, it's a square black component with 10 pins (4+6), very easy to replace. Part number is TMS91429CT, it costs about 10-15 USD/EUR. I've fixed sereverals with the same problem.Samsung flat screen tv no picture sound only, I ha - 1f3b7eaf-f628-4d68-a33f-c76593a89c0c.jpg
Posted on Feb 25, 2016
Claude Kayser
    Top Expert:
  • Samsung Master
  • 9,098 Answers
No Picture / Black Screen
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMay 27, 2011 - LN-T4669F No Picture / Black Screen. To determine why your TV hasno picture, start by follow these steps: Turn your TV on. Press the MENU ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention to ... TV Has Sound But No Picture Troubleshooting Guide ... So frequent overheating not only shortens the lamp life, but your TV picture life as well. ... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: ...
LCD Easy Fix (sound but no picture) - YouTube
My samsung tv does not power on ln32b360c5dxza
To troubleshoot a Samsung television that cannot connect to a network or particular apps, check to make sure there is a network connection. Use the remote control or buttons on the television to navigate to Menu, Network and then Network Status. If there is no connection, ensure the Internet router is properly connected to the television. If there is a connection and the problem persists, contact your Internet service provider.
If a Samsung television is experiencing distorted picture or sound with an external device, make sure the device is connected to the television correctly. If the connection is fine, perform a TV Self Diagnosis test by navigating to the menu, selecting Support, Self Diagnosis and Sound or Picture Test. It is also worth trying to change the picture size using the P. Size button on the remote.
To troubleshoot problems with lost settings, change the television to Home Mode by selecting Tools on the remote and changing Store Demo to the Off setting. Issues with the signal can be solved by selecting Source on the remote and running the Auto Program function to search for channels.
To access the on-screen manual for a Samsung television, press the Menu/123 key on the remote, and select Support from the menu. From the Support menu, select E-Manual. This opens the user guide on the television screen. From the screen, select the issue that the television is having.
Sometimes, the television simply needs a reset. To allow the TV to rest, turn it off, unplug it for 10 minutes, and then plug it back in, and turn it back on.
Apr 30, 2018 | Samsung Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
? 2:30
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung TV model un40eh53000fxza have sound but no picture
It all depends on the connections and cable.
If you are using a HDMI cable and have sound but no picture, then your TV probably needs to be fix.
if you are using a RCA cable or component cable, make sure that you have the correct TV input.
you don't specify what type of TV you have, but if I were you, I'll check the connections first.
Aug 06, 2015 | Samsung 40" 1080p 60Hz LED-LCD Smart TV...
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2014 | Samsung Televison & Video
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Televison & Video Logo
2,583 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
