Unfortunately, Generac does not provide wiring diagrams for their products. You will need to contact a local Generac dealer or service center for assistance.
This is an older generator. If you have the owners manual, there should be wiring schematics that give the wiring legends to all of the connections. I can't find a downloadable .pdf manual for your generator. If you don't have the manual, you'll likely have to take your generator to a service center for repair & testing.
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
You need to pull in two yellow wires called N1 N2 for sensing 220v. One red and one white called 23 and 194 those are your 12vdc transfer wires. And then last of all your 12vdc from battery charger. Hope this helps
