Question about Saniflo Plumbing
I experienced this exact same issue last month. I didn't think much of it, but decided to have our residential plumber come and look at it. It turned out that our water was running constantly and that it had to be turned down some. It was a very simple fix. Now, I am not sure whether or not that is your exact issue, but you might want to adjust the levels that your water runs at. There should be a knob behind your toilet that you can twist and turn to do that. However, if that doesn't work you might have to snake it to see if there is anything wrong going on in the pipes. Plumbing Mechanical Residential
Posted on Jan 04, 2016
SOURCE: Our pump continuously cycles everytime we flush
You have a water logged pressure tank. Replace
Posted on Sep 26, 2009
SOURCE: The toilet flushes but it seems that the water
with a very long pipe snake.
Posted on Nov 09, 2009
SOURCE: i have a saniflo macerator toilet system and when
Did you put an 1 1/2" vent pipe? It must be vented to the open air. Air must flow in and out of the vent pipe at all times so it can work properly. I had the same issue but after removing the cheater vent from the vent pipe it solved my problem. They do not recommend using an air admittance valve, cheater or mechanical vent on the vent pipe, as it only allows air to flow in or out.
Posted on Jul 20, 2010
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
The power it flushes with is relevant to the amount of water in the tank if the water in the tank is not up to the mark on the tank wall then adjust the water level float until it is. If this problem just started out of the blue then you need to look into an obstruction in the toilet water seal trap or possibly the drain.
Feb 18, 2011 | Kohler Home
Jun 08, 2010 | Home
Mar 22, 2010 | Toto Home
Mar 10, 2010 | Home
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Sep 27, 2009 | Home
Sep 24, 2009 | Flotec Corrosion Resistant Shallow Well...
Jul 01, 2009 | Saniflo Sanibest macerator with multiple...
Aug 09, 2017 | saniflo"" turboflush toilet"
438 people viewed this question
