Question about Sanyo Video Cameras
How to download to computer from internal memory
Keeps showing tap to see what happens with memory cards
Posted by MichaelDungey on
abdul rauf
    Dedicated:
    Visited the website for 20 consecutive days.
  • Sanyo Expert
  • 483 Answers
You must use the U S B cable to connect with a P C.
Posted on Mar 04, 2016
Lg optimus logic low system memory
Only some apps can be moved to the card. Here's how to check and move the ones that can along with some other tips for freeing up space in internal storage:
1.Go to the Home screen. Press Menu and tap Settings , then Applications, then All
2. Tap each app and tap "Clear Cache". Tap "Move to SD Card" if it's not grayed out.
3. If there are any apps that you've downloaded and don't use uninstall them. The phone won't let you uninstall system apps that are essential to the phone's operation. If you aren't sure if you need an app or not install ES File Manager (which can be moved to the card) and use it to back up the app to the memory card before deleting.
4. Open Messaging, if you have any picture messages, tap on the bubble containing the picture. Tap Save attachment. After the picture has been saved, tap on the bubble again and tap Delete message. Also delete any text messages you don't need.
5. If you use Gmail, open Gmail, tap Menu, then tap Go to labels, then Trash and delete everything in Trash. If you use a different email app delete everything in its trash folder.
6. Launch the Camera, press the Menu button, tap settings and make sure that "Storage Location" is set to "SD Card".
Feb 01, 2014 | Straight Talk LG Optimus Logic Cell Phone
Download photos to pc
If you're photos are saved in your phone's internal memory, transfer them first to the memory card.
To move files from the phone to the card, perform the following steps:
1. At the main screen, tap Menu.
2. Tap My Files.
3. Tap Phone at the top of the screen.
4. Tap the desired folder.
5. Tap the desired file.
6. Tap Options.
7. Tap Move to.
8. Tap Memory card.
9. Tap the desired folder.
10. Tap Open.
11. Tap Move to.
Once you have transferred your photos to the card, the next step would be transferring those photos from the card to your computer.
To move files from the card to the computer, perform the following steps:
1. Plug one end of the USB cable into the USB port on the top of your phone.
2. Plug the other end of the USB cable into a USB port on your computer.
3. Click File Transfer on the phone.
4. If required, tap OK on the phone to exit to the main screen.
5. On the computer, in the Removable Disk dialog box, click to select Open folder to view files using Windows Explorer, and click OK.
6. Navigate to the file on your memory card that you wish to copy.
7. Right-click the file and click Copy.
8. Navigate to the desired folder on your computer.
9. Right-click and click Paste.
10. When you are finished transferring files, tap Back on the phone.
11. Tap OK to exit the card reader mode.
12. Disconnect the USB cable from your phone and from your computer.
http://www.cellphones.ca/answers/how-do-i-download-photos-from-my-phone-to-my-pc/
Nov 16, 2012 | Huawei 2x Hb5a2h 1150mah Battery For U7519...
My kodak easyshare c182 will not show my pictures because it keep saying my internal memory is full
use the usb cord to get all your pics from the memory card, then delete them from the memory in the camera after downloading to your computer.
Sep 27, 2012 | Kodak EasyShare C182 Digital Camera
How do I delete pictures from a coolpix S4000
To delete individual pictures: while viewing the picture, tap the trash can icon on the screen, then tap yes when it asks for confirmation.
To delete all pictures on a memory card: format the card. TAP MENU, tap the wrench icon, select "Format card."
To delete all pictures in internal memory: format internal memory. Tap MENU, tap the wrench icon, select "Format memory."
The delete instructions are in the "Deleting Pictures" section of the manual (page 33 in my copy). The format instructions are in the "Format Memory/Format Card" section of the manual (page 150). If you need a manual, you can download one from the manufacturer's web site at
http://support.nikonusa.com/app/answers/detail/a_id/16763
Jul 16, 2011 | Cameras
Memory card filled and I took more pictures. Seemed to put those on the internal memory. What happened too or how can I recover the memory card pictures?
Probably one of two solutions.
First, the memory card should have all the pictures intact. If you are using the camera to review, you may need to just keep going back until the memory card photos show.
Another possibility is that the internal memory supersedes viewing the card memories. You may have to run a USB cable to your computer, download the internal memory photos, and then you can possibly see (on the camera) the memory card photos. It might be a good idea to download those photos to your computer too, if the computer has a memory card slot. Otherwise you will have to go through them and download via the USB again. Once you know the photos are saved, you can either change cards with a new one , or clear the old card and start again.
Good Luck
Mar 04, 2011 | Nikon COOLPIX L18 Digital Camera
Im trying to download my photos, from my camera onto the FinePix download, But when i click and wait for my camera to connect, Nothing happens. [email protected]
Okay I can see after reading through some of this cameras manual that the download features is done through the FinePix software. If the programing isn't loaded correctly or possibly you have the viewer up not the download window/program. It's a simple task and this system is way to complex. What possible problems you may be having is that the pictures you are attempting to download are in the camera memory not the memory card. Most point and shoot cameras can not download to the computer from camera internal memory they need to be transferred to a memory card first then to the computer. If the memory card is being used and not internal memory I'd suggest looking at the memory card to see that it's not locked I'll include a generic type diagram to show this little switch.
Okay a quick recap, memory card lock, possible internal memory trying to download, camera to computer software issues, failure to connect the USB cable to the USB port on the computer.
If you don't mind a suggestion I'd suggest buying a card reader and bypass the camera and software to download. The card reader can be purchase as a single card to fit your memory card type or a multiple memory card reader, which ever the computer looks at is as an external device, like an external Hard Drive or printer. You need to make a folder to put the pictures in "My Documents" or "Documents" "PC or Mac".
Transfer the camera files into the folder which can be opened in your FinePix programing. Then do a safely remove of the device or eject PC or Mac what every you have make sure you shut off the feed before taking the memory card out. Then format the memory card in the camera cleans all the old pictures off and make the camera and memory card compatible once again.
Hope this was a help and didn't confuse the issue, Robert in Canada
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
I have a Fuji FinePix F480 which is brilliant but it isn't downloading all my shots onto my computer. It is showing a message that I have internal pictures. My question is how do I get these pictures to...
I've attempted in the past to download from the internal memory to the computer before with no success. What you can do is put the memory card back into the camera and transfer the internal pictures to your memory card (your camera refers to these as "frames"). I'm not sure if you have a manual or not but what needs to be done is selecting copy using the multi-control button on the back of the camera select "IN" for internal and arrow from internal to card. the only sticky thing about this is you need to do one "frame" at a time. Make sure you have the room on your memory card before doing this. You might want to format the memory card first before you do the transfer from internal memory to your memory card. Then once the Internal "frames" are all on the memory card you can down load them to the computer as "normal"
Dec 18, 2010 | Fuji FinePix F480 Digital Camera
How to uninstall apps like..skyfire ,openweb radio
You just have to copy the .cab file (which is the application installation file) to either your phone internal memory or the memory card (if it is inserted, that is), and tap over it. You will, then, be prompted to install the application either on the internal memory or memory card. Then, it should be available under 'Start > Programs' (depenidng on what you have installed, it might show under 'Start > Settings'), ready to be launched. After the installation, you are free to delete the .cab file, if you want (of course you can keep it there, for future installations, if something bad happens).
Hope you are able to install your applications soon.
Regards, Carlos
Jun 09, 2010 | HTC Tilt 8900 Smartphone
When i switch on the camera it show internal memory is full and nothing can happen.
If the pics are important, download them to your computer. Then, with no card in the camera, go into the camera menu and find "format"...follow the on-screen instructions.After that, insert your memory card and promise yourself to never use the internal memory again.
May 17, 2010 | Kodak EasyShare C140 Digital Camera
I can't access current photos from memory card, only old photos show up stored in built in memory. Also can not access "copy" from the menu, and nothing will download to my computer. All this worked fine...
"copy" is accessed from the playback menu. If that isn't available, decide if the pics stored in the internal memory are important. If not, format the camera with no memory card inserted to erase the internal memory. If you need those pics, then download them to your computer first...then format. Next, go into the menu and find "reset"..follow the on-screen instructions. Then, purchase an inexpensive card reader and download the pics from your memory card to your computer.(and promise yourself to use the card reader from now on...and remember that after downloading, use the "safely remove hardware" icon in the bottom right of your computer screen...don't just yank out the reader!). Finally, format the card in your camera and promise yourself never to use the internal memory again.
Jan 09, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Video Cameras Logo
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Nicola Conroy
abdul rauf
abdul rauf
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
