Televison & Video Logo
Christopher Sloan Posted on Jan 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My jvc has picture but it is double and reversed
Claude Kayser
Level 3:
Top Expert:
  • JVC Master 9,098 Answers
  • Posted on Jan 01, 2016
Claude Kayser
JVC Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061453
Points
28436
Double Image JVC - AVS Forum ' Home Theater Discussions And Reviews
www.avsforum.com/forum/63-rear.../546325-double-image-jvc.html
Jun 4, 2005 - 30 posts - ‎11 authors
Have a JVC 52 , only a few months old. ... That looks like my CRT RPTV if I mess with the convergence. ..... I hope your repair isn't that drastic, but you won't know until after the service tech gets there. .... Started out with a double image, then mirror image, then finally the blue and red went out totally leaving ...
2answers
Manual JVC TD-W207
Type: auto reverse, double compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x record/playback, 1 x playback, 1 x erase
Motor: 1 x capstan, 1 x reel, 1 x mechanism
Tape Type: type I, CrO2, Metal
Noise Reduction: B, C
Headroom Extension: HX Pro
Frequency Response: 20Hz to 17kHz (Metal tape)
Signal to Noise Ratio: 73dB (dolby C)
Wow and Flutter: 0.08%
Total Harmonic Distortion: 0.8%
Input: 80mV (line)
Output: 300V (line)
Dimensions: 435 x 133 x 328mm
Weight: 4.9kg
1helpful
BLURRED DOUBLE IMAGES
need to replace convergence ic stk392-110
Double picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
I ART PRO JVC 56
You will need to replace the convergence iCs there are two of them they are both STK392-110 Ics you will also need the JVC convergence resistor kit. You can get the ICs and resistor kit at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Double picture
does your TV has the stat adjustments in the CRT or near the chroma IC it is a trimmer resistor or a rheostat try to adjust it...
2answers
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
