SOURCE: 95 Buick Fuel Pump Fuse or/and Relay Locaton
fuel pump relay located in relay center under hood at center of firewall
SOURCE: need location of fuel pump relay
This relay will be in the Power Distribution Center under the hood in the engine bay. Thanks for using fixya!
Sincerely,
jC
SOURCE: Need location of fuel pump on a 1992 BMW 525i straight six engine
The fuel pump is located under the back seat on the passenger side. You will find an access cover and will need to remove the screws. You should be able to listen for the pump while someone cranks the car. Also I believe there is a large green w/ blue trace wire and an equally large brown wire at the connector. Check for battery voltage across the two wires. The fuse for the pump should be in the fuse panel under the hood.
SOURCE: fuel pump fuse located on 1997 gmc sierra
The fuse is actually a Relay Switch and its located in the Fuse Relay Center on the driverside of the engine compartment. The Black Box is labled Fuse Relay Center, the diagram on the cap displays which Relay is the Fuel Pump relay...the Relay switch is usually $8-$15 depending on where you shop
SOURCE: Fuel filter and pump location
The fuel pump is located in the fuel tank while the filter is located in the hood close to the panel.
Testimonial: "Good info but what panel does he mean? "
