So your set up to sew zig/zag and only get the zig or the zag : )
Could be top thread tension is too high. Switch to a straight stitch and reduce tension until top thread starts to appear on bottom. Then go back to zig/zag and see if it sews properly.
If still dropping stitches, check the needle is not bent and is fully inserted into the holder. Clean the bobbin, hook, and race per machine instructions. Try reducing the stitch width and see if that makes any difference. If still not right then timing may be off.
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
make sure the bobbin is inserted correctly into the bobbin case and that the bobbin case is inserted correctly, if it's a side or front loading machine
also could be a problem with the gear, they might be damaged or broken,, if you keep having the problem, have the machine checked
you start with the broad zig zag stitch bar across the top then you go down the left side using a smaller zig zag stitch then you make the the broad zig zag stitch at the bottom then you make the smaller zig zag stitch on the right side all the way to the top broad zig zag stitch & your done the right side zig zag does not go beyond the top broad zig zag stitch
put in a new needle rethread the machine top & bobbin--use every thread guide make sure the zig zag settings are correct it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop is the fabric & thread & needle compatable with each other? did you use every thread guide when threading the machine? is the bobbin in correctly? is the bobbin warped?
Turn the lower knob on the right hand side of your sewing machine. This is the control for the stitch selector (like zig-zag, buttonhole, etc.). You will see 3 straight stitch settings. One is for left, one for center, and one for right. Align the orange indicator with the center line & voila.
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
I do not have a buttonhole foot, but I can tell you how I do it with the zigzag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zigzag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zigzag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zigzag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zigzag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zigzag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zigzag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zigzag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
