Question about Kenmore Elite 45986 Front Load Washer
I just moved and all of a sudden it won't drain completely
Kenmore Elite HE4 washing machine doesn't drain all the way and it leaked all over the floor
Posted by Lore' Chalfant on
Softener reservoir doesn't drain when washing. Kenmore Elite about one and a half years old.
Possible blocking on the drain from the tray, remove the accumulated softener from the dispenser , clean and check the drain line. It can be blocked with residue or dirt.
Mar 17, 2013 | Washing Machines
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
Water does not drain
see this causes:
It spins, but doesn't pump
drain line clogged, ome sock in the outer tub, use pliers for large hose and pull out,test the pump can be faulty.
It doesn't spin or pump
frozen pulley pump, replace, move manually see the diagram, if not replace
It pumps, but the water returns
improve the drain line, if the drain hose reach the 4 inch cut of the excess, if is lower, install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Kenmore Elite 45986 Front Load Washer
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
May 27, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Water leak from Kenmore elite
If the leaks happens during drain cycle, this is usually because of a leak on the drain pump hose, or because of a faulty drain pump that is leaking.
As the appliance must be taken apart and the pump may need replacement, it is better to call a repairman to do the job.
Check that leak is not from drain hose, from water supply hoses, or from gasket first.
Dec 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 'Elite' washing machine
remove the bottom panel is is held in place with 3 torx screws
Apr 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
