Tried to delete pics and got a "Read Error" ?, how do I get rid of that?
Transfer or delete the pictures via a card reader. Put the card back into the camera and format the memory card. If the memory card doesn't work properly after this action, it is probably faulty.
You can find a direct download link to the manual of your camera here:
https://www.google.nl/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjGm-7c1cjKAhUFOg8KHUCfDy0QFggfMAA&url=https%3A%2F%2Fwww.fujifilmusa.com%2Fshared%2Fbin%2FF10_Manual.pdf&usg=AFQjCNEVT02eTf6D5OmCznGcf9ITzORRPQ&sig2=FuRTBsO9vYgA9V5dEF-iBA&bvm=bv.112766941,d.ZWU
SOURCE: zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
SOURCE: My FINEPIX S1000fd fujifilm camera ZOOM ERROR
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
SOURCE: my fujifilm finepix s1500 tells me there's a read
i have the exact same problem it works again when you erase the memory card i think its nont the actual memory card but a general camera problem ive tried both my sd 8 gb card and sdhc 16 gb card and both have the same problem
SOURCE: Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
