Question about Sunpentown Spt Su-4010 Ultrasonic Dual-mist Warm/cool Humidifier With Ion Exchan
My SPT humidifier works but only when the mist setting is at maximum, looking for any advice/suggestion/help ....
Out of warranty, looking to attempt to fix it myself, the problem now is wet floor whenever unit is on for some time already tried soaking base unit with vinegar. Also clean as much as I could without disassembling unit.
Posted by davidl8008 on
OLDS 97 REGENCY - wet interior issues. What do I do to correct this?
Do you know where the leak is coming from ? Have you done any type of repairs or troubleshooting to repair this leak ?
Dec 09, 2016 | Cars & Trucks
Kenwood car stereo face got wet and now won't work, how do i fix it?
If the unit is already fried you may try to soak it in the highest alchol % of rubbing Alcohol for a day then allow the unit to dry Which should happen within a day or so because of the evaporation rate of the alcohol. This should remove the internally locked water and allow for the unit to resume Function without internally shorting.
Jun 06, 2013 | Kenwood KDC-MP242
My 2002 Ford Taurus passenger floor (front) is soaking wet. I have read that it could be a plugged hose. I am a female and have no experience...where do I find the hose to work on this? Can't affo
Sounds like the AC condenser drain is plugged. Do you notice a puddle under the right front while idling with the AC running? If not, the drain is plugged should be an easy and cheap fix at any local garage.
Jun 25, 2012 | 2002 Ford Taurus
Wet floor mats and stinky ac/heat unit...
Your drain lines are clogged, and need to be blown out with compressed air. What you are smelling is mold.
Nov 17, 2009 | 2000 Volkswagen Beetle
Soaking wet floor mats - '98 Mazda Protege ES
drain pipe from the interior ac unit ,look for rubber outlet pipe outside firewall passenger side and unblock the end
Aug 30, 2009 | 1998 Mazda Protege
I have an intertherm split unit and it is getting water all over
hot water heater has a relief valve on it and should have a pipe going down to the floor stick your finger in the pipe and if it is wet inside the pipe that is your source how old os the water heater dry up the floor with towels and leave a/c of for 24 hours not as wet then possible crack in new condensate pan
Jun 05, 2009 | Heating & Cooling
Wet rear floor
Have you by any chance jacked up the passenger side, or got vehicle on a hoist to make sure there isn't any plugs on the underside that may have fell out? They could be round or oval metal or rubber plugs, probably in that area.
Feb 13, 2009 | 1999 Mitsubishi Eclipse
Clothes soaking
Gregg, remove the bottom panel. Right in front you will see the filter. Get a flat pan and remove the filter cover. Pull the filter strainer out and remove the lint and whatever else you find. You should be fine after that...Catriver..post back
Oct 02, 2006 | GE Energy Star WCVH6260F Front Load Washer
Sunpentown Spt Su-4010 Ultrasonic Dual-mist Warm/cool Humidifier With Ion Exchan Logo
56 people viewed this question
Top Sunpentown Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
