Runs, but why does it shut down after a few minutes?
Filters are clean, other check points from manual have been cleared
Posted by Kathy Hall on
richie46
    Top Expert:
  • Heating & Co... Master
  • 12,962 Answers
Appears to be a thermal issue. See if there is also a fan that is supposed to be running. If there is one and not working, then the unit is overheating and shutting down to protect itself and you.
Posted on Dec 29, 2015
5 Related Answers
Anonymous
SOURCE: will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Posted on Jan 21, 2009
Anonymous
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
Anonymous
SOURCE: heater runs for a few minutes then shuts down
need a manul
Posted on Nov 12, 2009
Anonymous
  • 288 Answers
SOURCE: desa model tb103 wont stay lit.
at first i thought this was a bad flame rod but the fact that it burns on low and not on high tells me that it is not getting enough gas since it burns less gas on low. there will be a tap on the burner side of the regulator, take off the cap and turn the screw clockwise to increase the gas pressure. do this in small amounts until it corrects the problem. If you have or can get a manometer, the gas pressure should be set to @7 inches of water column
Posted on Dec 09, 2009
Anonymous
  • 540 Answers
SOURCE: ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Posted on Dec 18, 2009
My Hoover U6458-900 shuts off after a few minutes of vacuuming. I let it set a few minutes and it will start up again.
It sounds as if the motor has overheated at some point, and damaged the thermal protector fuse in the motor compartment. Clean the filters thoroughly, change the bag, and try to operate it. If it still shuts down, the thermal protector will need replacement. ( Part # 47534032 )
Mar 02, 2011 | Vacuums
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
We have a dyson root cyclone and it shuts off after a about 5 minutes of running. Then after about 10 minutes it will run again.
Your description is typical of a machine that's overheating. This is almost always caused by a blockage, as restricted airflow can't keep the motor cool and the automatic cut-out shuts the machine off. It re-sets itself when it's cooled a bit. Check your operator manual for how to clear blockages, and also check that your filters are clean.
Nov 28, 2009 | Vacuums
How many quarts do i put in after i change my oil
What engine?
General rule, have 6 quarts available. Put in 4 quarts, check level. If still low, add quart. Start engine, run for a minute. Stop, re-check oil level and fill to point on dipstick.
Aug 12, 2009 | 1999 Chevrolet Silverado 1500
My viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
