SOURCE: PUK CODE - PHONE BLOCKED
Yes There is but it is only provided by the network opperators
you will need to contact your provider
SOURCE: UNBLOCK MY PUK CODE
PUK is Personal Unblocking Code. You can't get it here. Every sim has a different PUK code for it. Your mobile operator may help you in this problem. Contact them.
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
Your PUK code is blocked...U must have entered wrong PUK thrice...To unlock cal ur service provider a get a new PUK code..cal to ur service provider from some other phone...dey will ask ur sim no...
You need to input the PUK code first before it will allow yuo to do anything. usually PUK is printed on the SIM's packaging.. Kindly check the plastic card where the SIM was attached when hyou purchase it. It says PUK 1 and PUK 2.. Scratch the gray part and that would be your PUK code
