The plug in for roku has a connecting cord that is supposed to plug in the bacl the colors are red, white and yellow but their is no yellow. I am soo aggravated. I PLUGGED THE YELLOW INTO THE GREEN SLOT AND NOW ITS WORKING. THANKS EVERYONE!!!
SOURCE: Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Try changing the menu from NTSC to pal or vice versa for output.
