Still need to know what the problem here is. To address the amp issue is easy. Most factory installs use only the amp that is built into the radio deck and do not have an external amp. If you do have an amp...which would be a higher end factory install then you are using your deck as the preamp and then going to the amp. You need to find that amp for the hook up.
SOURCE: AMP BYPASS
You should be Able to Bypass the Factory amp and Relocate the Speaker Wires to the New Amps and be Fine. Let me Know if you need More Help! Please Rate my Response, I need all the Help That I can Get! Thanks!
SOURCE: I AM TRYING TO HOOK UP AN AMPLIFIER IN A STOCK 04'dodge stratus.
you should be able to hook it the power antena at the power intena there should be 3 wire one power one ground and the other is the one your looking for take a volt meter or a test light and find the one that gets power when you turn on the radio and turns off when you turn off the radio
No sound from speakers on 04
gmc yukon
http://repairhelpcenter.blogspot.com/2012/10/no-sound-from-speakers-on-04-gmc-yukon.html
these will help.
Thanks.
