Question about HP PSC 1410v All-in-One Printer
My printer wont print
My printer paper light keeps blinking, thought the paper tray is filled. What step should i take?
Posted by treasure4u on
  • leh1987 Apr 01, 2008
    My check paper light keeps blinking... i looked inside the printer area and seen that there is a little plastic strip hanging from both side of where the ink cartridges go....and the ink cartridge piece will slide very fast and make a loud noise when trying to print???? what should i do?
miss_merdur
Leh1987, that piece of plastic you see hanging, is what the ink slides on, right now its broken so your ink cartridges are slamming back and fourth had the same problem, have to take it in and get the plastic piece either replaced (if damaged) or put back on.
Posted on Apr 09, 2008
I have a DeskJet 5940 which was about to be thrown away and I thought I'd have a go fixing it. I tried, but it simply won't work. When I print something it pulls one paper nicely from the tray, feeds it...
  • Reset the product
    1. If the Power light is on, press the Power button (c01346625.gif ) to turn the product off, and then continue with the steps. If the Power light is off, go straight to step b.
    2. Unplug the power cord from the wall outlet.
    3. Plug the power cord back into the wall outlet.
    4. Press the Power button (c01346625.gif ) to turn the product on.
    5. If any lights are still blinking, service the product.
  • If the print-cartridge status light stops blinking after you reset the product, follow these steps to make sure the driver settings are correct, and then try printing again.
    1. Open the printer driver.
      • Windows 2000 : Click Start , point to Settings , and then click Printers .
      • Windows XP : Click Start , click Control Panel , and then click Printers and Faxes .
      • Windows Vista : In the Windows taskbar, click the Windows icon (c01364735.gif ), click Control Panel , click Hardware & Sounds , and then click Printers .
    2. Right-click the icon for the product, and then click Printing Preferences .
    3. Click the Paper/Quality tab.
    4. In the Paper size: drop-down menu, click the appropriate paper size.
    5. In the Paper type: drop-down menu, click the appropriate paper type.
    6. Click OK to close the dialog box.
    7. On the product, press the Resume button (c01421637.gif ) to continue printing.
    Also Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
  • Dec 17, 2010 | HP Deskjet 5940 Photo InkJet Printer
    My HP 610C printer yellow light is blinking after the paper is taken in. The power light is steady. Therafter the yellow light blinks continuosly. Please help.
    Follow each of these steps until the problem is resolved:
    • Remove the paper from both paper trays.
    • Press the power button once. Wait a moment for the paper jam to clear.
    • If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
    • Remove the rear access door.
    • Remove the paper jam through the opening at the back of the printer.
    • Replace the rear access door.
    • Reload the paper into the paper In tray.
    • Print the document.
    Sep 29, 2010 | HP Office Equipment & Supplies
    I have filled the paper tray with paper and will not print
    Try to flip down the back cover and lower the flap that covers the rollers. On the inside of that flap, right in the middle of it, you will see a small, one inch long lever that helps keep the paper up against the roller. This lever was moved to the left a bit to far, so I nudged it to the right. As soon as you do this, the light should stop blinking and the printer should work.
    Jan 19, 2010 | Brother HL-2040 Laser Printer
    Printer mechnical error
    Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
    • Change the printers print mode setting.
    • Change the printer's paper type selection.
    • Use a different brand of label media.
    There is a paper jam Follow each of these steps until the problem is resolved:
    1. Remove the paper from both paper trays.
    2. Press the Power button once. Wait a moment for the paper jam to clear.
    3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
    4. Remove the rear access door.
    5. Remove the paper jam through the opening at the back of the printer.
    6. Replace the rear access door.
    7. Reload the paper into the paper In tray.
    8. Print the document.
    There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
    1. Remove and then reinsert the print cartridge(s) into the printer.
    2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
    3. Manually clean the print cartridges and print cartridge cradles:
      • Open the printer cover and wait until the carriage moves to the center.
      • Press the Power button to turn off the printer.
      • Disconnect power cord from the back of the printer.
      • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
      • Lightly moisten a cotton swab with distilled water.
      • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
      • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
      • Reinsert the print cartridges.
      • Close the printer cover.
      • Connect the power cord to the back of the printer.
      • Press the Power button to turn on the printer.
    4. Calibrate the print cartridges.
    5. If the light is still flashing, replace the print cartridges.
    Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
    1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
    2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
    3. Remove and then reinsert the print cartridge(s) into the printer.
    4. Print the document.
    5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
    6. Try printing again. If the problem continues, replace the print cartridges.
    Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
    Flashing on/off light on hp deskjet 3520 printer
    Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
    c00374282.gif Solution
    Close the cover.
    Cause
    Printer cover is open. Solution
    Cause
    The printer is out of paper. Solution
    • Change the printer's print mode setting.
    Cause
    The printer has difficulty picking up label media. Solution
    2. Press the power button once. Wait a moment for the paper jam to clear.
    Cause
    There is a paper jam. Solution
    Cause
    There is a problem with a print cartridge. Solution
    Cause
    The print cartridge has partial loss of electrical interface with the carriage connections.
    Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
    I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
    Possible Solution to your issue!
    Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
    1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
    2. There is a paper jam in the printer.
    3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
    4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
    A. Pull the tray out of the printer and remove any paper.
    B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
    C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
    D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
    E. Slide the tray back in the printer.
    5. The tray 2 paper level indicator is stuck.
    6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
    A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
    B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
    7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
    A. Turn the printer off.
    B. Press and hold down the green GO button.
    C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    D. Release the GO button.
    NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
    E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
    Feb 23, 2009 | HP LaserJet 1320n Printer
    Paper Light Blinking
    make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
    hth,
    razors
    Feb 05, 2009 | Brother HL 5250DN Laser Printer
    Printing problem with HP 2015 Laserjet Printer
    If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
    Hope that helps - Ghost
    Oct 27, 2008 | HP LaserJet P2015dn Printer
    Light blinking
    Step1
    If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
    Step
    Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
    Step
    If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
    Step
    If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
    Jun 02, 2008 | Epson FX 1170 Matrix Printer
    HP PSC 1410v All-in-One Printer Logo
    64 people viewed this question
    Ekse
    efs_perpends
    efs_perpends
