SOURCE: Troy-bilt storm 2840 fuel line not getting fuel to carburetor
Gasoline brakes down over time. What happens all the things the facilities uses to make gas separates and you end up with all the bad stuff. You may need to remove fuel tank and clean it out plus the carb may need the same thing done to. If you have to clean the carb get a rebuild kit. It's easy to rebuild but you may need to take the carb with you so they can get the numbers of it to make sure you get the right kit.
Testimonial: "Thanks for the response. I went back to work on the machine and was able to remove a couple of the plates protecting the fuel line and carb. Turns out what I thought was the fuel line to the carb was actually the choke line! I found the fuel line from the tank and bled out all of the fuel from the tank. After adding fresh fuel, the darn thing cranked right up!"
