HP Officejet 6600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
j
jean whillier Posted on Dec 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with printer or ink system
Ink cartridge will not center for removal when cover door is opened will not respond to power cycleing
Claude Kayser
Level 3:
Top Expert:
  • HP Master 9,098 Answers
  • Posted on Dec 28, 2015
Claude Kayser
HP Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061719
Points
28436
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
1helpful
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Why will my ink cartridge not move to the center so i can tak e it out.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Printer can not print Error Number 5200
To solve your problem follow the instruction step by step. Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display . Thanks
2helpful
Hi, my canon MP250 is displaying the error P08 and error 5200 on the computer. Can you help me please
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Alarm light is on and it gives an error code 5200 when i try to print from my cannon MP 495
Error 5200:
3answers
HOW TO CHANGE INK CARTRIDGE
Hello Doca,
Please visit the link provided below to replace the cartridge :
http://files.support.epson.com/pdf/nx400_/nx400_qr.pdf
My pritnter says error 5200 i have switched offand on with no avail please help
2answers
Gives me error 5200
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
7helpful
The canon mp 130 printer says error 5200 and will not print.
3. Plug electrical cord back in, when ink cartride carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
Thanks, Joe
Epson c20ux -ink cartridges installation
Power on
Open door or front top of cover that covers cartridges.
Systen should move ink carrage to center so you can take out old and put in new.
Close door/cover and should get some data on Monitor to follow so system recognizes new cartridges.
If no work u have some type of a problem in printer.
I'm assuming you don't have a paper jam or anything. If you do must clear.
Luck
JC
k24674
Grand Canyon Tech
Grand Canyon Tech
