Questions, Troubleshooting Help & Support - Fixya
www.fixya.com/troubleshoot
My coship CDBV2500E Recivier has 7U on the display and is stuck on one channel , is there a way to reset or default the unit given I can't access the menu ...
How to remove this info off the screen? The info stays all the ...
www.fixya.com/.../t26024365-remove_info_off_screen_info_stays_all
14 hours ago - My coship CDBV2500E Recivier has 7U on the display and is stuck on one channel , is there a way to reset or default the unit given I can't ...
My kawai mr370 is stuck on the loudest volume and does
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
SOURCE: Samsung LE32N7 - Analogue channels ok - Freeview
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
SOURCE: lost channel connections
Go to the menu and then enter your choice out of them like find channels or scan/scan channels.
