Question about Mitsubishi Televison & Video
I have a Mitsubishi 1080 Series HDTV big screen not turn the power button TV comes on then TV shuts back off
Posted by John Martinez III on
  • John Martinez III Dec 27, 2015
    Mitsubishi HD 1080 series powers up then shuts back off even after I hit both input and the other button and release them still powers off
NoName Jack
  • Mitsubishi Master
  • 1,150 Answers
Hi John
Check the switch mode power supply inside the TV.
Caution.... lethal voltages
The power button is digital these days. That is... it does not have the AC power directly connected to it. Like a normal appliance.
It's a Computer.
Nowadays, the switchmode power supply module converts the incoming AC power to the lower DC voltages required by the other circuit boards.
It uses lots of Electrolytic Capacitors to clean up noise in the DC power. Being Electrolytic they are prone to leaking & bulging so they don't do their job. They won't hold a charge. By pulling the plug and restarting, you have found a way to overcome the problem. But only temporarily. When the Cap goes fully bad, you won't be able to start the TV any more.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 5v to 25V 1000uF or 3300uF.
Replacement Caps can be slightly higher values (not lower) depending on available space.
Also... a higher temperature rating is beneficial.
See Cap Replacement Here
NOTE: Even when Disconnected from the Mains.... Capacitors on the SwitchMode Power Supply board on the 110vac / 240vac Mains Side....can supply a shock hazard to unwary people.
The DC Side is far safer at 5 to 20v
But... There is no Really High 15 to 25Kv inside Digital TV's any more. So... You don't need to leave TV disconnected for a day to discharge these voltages as stated in the attached video.
Samsung TV Power on Problem Capacitor Replacement
How to Repair Your Plasma TV With Blinking LED
How to Replace an Electrolytic Capacitor
Posted on Jan 03, 2016
2 Related Answers
Anonymous
  • 23 Answers
SOURCE: my 53 hdtv 1080 big screen the green light in
Unplug for a few should correct!
Posted on Mar 04, 2010
hdemel
  • 23 Answers
SOURCE: had power outage, then when power back on in
This is a solution that was previously posted by Fix-Ya Guru Freetek for the exact same TV and same situation:
http://www.fixya.com/support/t2115048-green_timer_light_blinking_tv_turn
Posted on Mar 05, 2011
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Had power outage, then when power back on in house, tv green light keeps blinking even after unplugging and pressing reset button and attempting re turn on. we use a surge protector, tv is 65"...
Mar 05, 2011 | Mitsubishi Televison & Video
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
Televison & Video Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
