Question about Samsung Refrigerators
Samsung refrigerator r s2533Sw.power cool flashes and temp fluctuates between38Dec and26 Dec
Posted by Raymond debraine on
ptpumpman
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 408 Answers
Hi, you have a problem with the thermostat on the machine. You have to get it look at to see if you need a new thermostat.
Posted on Dec 27, 2015
5 Related Answers
Anonymous
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
Anonymous
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
Anonymous
  • 5 Answers
SOURCE: Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Posted on May 22, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
Posted on Jun 17, 2009
Anonymous
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
SAMSUNG REFRIGERATOR MODEL RT72KBSL1/2012, IS HAVING TEMPERATURE FLUCTUATIONS. for ex, temp reaches -20 than decreases to 9 degree n again -20 n vice versa. There is fluctuations also on display.
Sounds like your thermostat is sticking on and needs replaced. Before replacing check the setting on the thermostat. Almost all themostats are calibrated to maintain the proper temperature in the correct range when the thermostat is set to the mid position. If your thermostat is number 1 to 9, place it at 5. Refrigerator and freezer do not cool faster setting the controls to the coldest setting. This is misconception of a lot of people.
Sep 29, 2014 | Refrigerators
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Model rb215lash bottom freezer not staying cool
is the condensor fan operating back in the lower area by the compressor,if not the compressor will cycle from heat and you will have fluctuating temps
Aug 31, 2012 | Samsung RB215LASH
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
May 16, 2017 | Samsung RS265LBBP Side by Side...
I am a florist with a 26 feet src refrigeration box (unit), I cannot control the temp at the desired rate, it keeps fluctuating to a higher (hotter) temp. Need your advise
your going to adjust the thermostat setting if your thermostat is digital type you press it yuor desired temp. ex from 10 to 1 to adjust it to cool if your thermostat is analog to adjust it to cool rotate the knob clockwise to adjust the setting to cool but observe it to get you desired temp.
Mar 02, 2011 | SRC Refrigeration LD126-4 10'6' LongDoor...
Refrigerator side temp reading fluctuation and not cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 09, 2009 | Samsung RS2534 Side by Side Refrigerator
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
Jan 26, 2009 | Refrigerators
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
99 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
