Question about Metra Ford F 150 Truck 1999
Fuse box what fuse goes to what wire
1999ford 150 extended cab fuse box dash drivers side
Posted by Dal Walsh on
1 Related Answer
Edwin Aquino
SOURCE: My interior light wont turn off, even with the
there's two plastic switches on the side of the dashboard ,when you open the door they come out sometimes the switches push into the dashboard and stay on look for them if theyr missing they fell inside the dashboard replace them.
Posted on Feb 05, 2012
Why does my 2007 f150 4 x 4 not engage?
Visual Inspection Chart Mechanical Electrical
  • Half shafts
  • Integrated wheel-ends (IWEs)
  • Shift lever and/or linkage
  • Driveshaft and universal joints
  • Vacuum leaks
  • Fluid leaks
  • Matching tire sizes
  • Transfer case
  • Central junction box (CJB) mini fuses:
    • 11 (10A) (IWE vacuum solenoid)
    • 28 (5A)
    • 29 (15A)
    • 30 (15A)
  • CJB fuse 111 (20A)
  • Wiring harness
  • Mode indication switch (MIS)
  • Synchronization clutch
  • Connector(s)
  • Integrated wheel-end (IWE) vacuum solenoid
  • Circuitry
May 17, 2016 | Ford F-150 F150 Extended Cab
How can I wire into the CJB of a 2005 F150, to utilize one of the unused fuse locations? Is the distribution panel (fuse box) sealed, or can it be opened to access the fuse terminals underneath? Are there...
The fuse box is in the kick panel of the passenger side floor board. Beware this is a solid state fuse box so if you blow it you have to replace it all
Mar 01, 2015 | Ford F-150 F150 Extended Cab
Why did my windsheild wipper stop workinf
Could be the FUSE, the wiper motor, or the switch itself.
Check the fuse first. There should be a fuse box under the driver's side dash somewhere, and the inside panel will most likely have a chart showing which fuse controls which.
If the fuse is fine, checking the wiper motor with a voltmeter will determine if any power is getting to the motor. If there IS power going there when the switch is ON, it's not the switch at fault, it's the motor.
Hoping for your sake it's the fuse.
Jun 24, 2014 | 2001 GMC Sonoma Extended Cab
All the elecrical cuts out while acclerating. Lights, heater motor, emmissions light comes on. Once I get to speed everything goes back to normal. Ehgine has just started misfiring, seems to cut th
Here is something that might be related to your issue, carefully inspect fuse box under dash, driver side. See if it is wet/moist with oily liquid on fuse side and wire side behind. If it is, its brake fluid from the brake master pressure switch that has failed causing brake fluid to be pushed thru the wiring all the way to the fuse box , shorting out the electrical system. The repair would require replacing the brake master pressure switch with an updated pigtail (supplied with new switch), and replacing the complete fuse box assembly, and I would recommend cutting and splicing new wiring from the brake pressure switch to the fuse box.
Dec 27, 2013 | 1998 Ford F150 Regular Cab
Where is the fuse for the cigarette lighter 2006 ford f-150 extended cab?
I believe it's under the hood in the main fuse box.
if not, it's under the dash on the left side
Dec 26, 2010 | 2006 Ford F-150
My tail lights, license plate light and dash board do not light up, why?
They should all be on the same circuit so I' check the fuses 1st.
Dec 26, 2010 | 2001 Nissan Frontier Crew Cab
I can't locate the hazard flasher fuse on my 87 F-150.
About your 1987 Ford Truck F150 1/2 ton P/U 4WD 5.0L FI 8cyl...
Application: Hazard
The Flasher is located: Front seating area, driver side, driver side of steering column, behind lower dash panel, mounted on rear of fuse block
Application: Turn signal
The Flasher is located: Front seating area, driver side, driver side of steering column, under dash, mounted in upper left corner of fuse panel
Hope helps (remember comment and rated this).
Aug 05, 2010 | 1987 Ford F 150
F 150 Head light issue
You know the fuse for the high beams is good ( Cab fuse panel fuse # 16 ) and the pass low beam fuse ( cab fuse panel # 26 ).
Might want to check cab fuse panel fuse #28 ( this is the driver's side low beam ).
If this fuse has power on both sides ( with the low beams on ) next you can pull the headlamps, and check for power at the connectors, but depending when the last bulb change took place, I would say you need need bulbs. ( need at least 1 for the high beam out )
Confirming with a meter at the headlamp would be a good idea, before spending the money.
The bulb connector has 3 pins.
Black wire is ground on both sides
Light Green w/ Black stripe wire is high beams on both sides
Driver Lo = Dark Blue w/ white stripe
Pass Lo = Dark Green w/ Orange stripe.
Nov 16, 2009 | 2002 Ford F150 Regular Cab
Metra Ford F 150 Truck 1999 Logo
108 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
