Question about LG Televison & Video
Sound Appeal sound bar set up. Not getting sound from tv except tv's speakers. Help!
I have hooked the sound bar up and I get sound from the fm setting and the blue tooth works fine. I am not getting sound from my LG smart tv however.
Posted by Dale Allen on
Electro Med Services
  • LG Master
  • 6,694 Answers
You have to check the sound setting of your tv. In most of the lcd tv there are two option that you can select. Internal speaker of the tv and external speakers while using sound bars or other amplification devices. Fist of all Check that setting. Check the link bellow to understand How to setup a sound bar to your tv.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=QQ3zFnnsiMs
Posted on Dec 27, 2015
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
How do I get operating instructions for this sound bar
1. Plug it into a power outlet and turn it on.
2. Put 2 AAA batteries in the remote control.
3. Dock your iPod or iPhone into the docking connector.
4. You can hook up the sound bar to your PC (from the RCA(L/R) audio output on your TV to the RCA audio input on the bar) or to your PC (from the headphone jack on the PC to the LINE IN jack on the bar). Obviously, you can hook it up to both TV AND PC only if those two are located close to each other.
5. Using the remote, select the audio source/input you want to listen to: iPod/iPhone, FM Radio (an FM tuner is built into the sound bar), TV or PC.
Hope this helps.
Dec 20, 2014 | Apple Ilive Itp100b 2-channel Speaker With...
I have a samsung lcd tv that I am attempting to hook up a craig sound bar getting no sound out of external speaker
Check the settings on your tv. Many tv's need to have the internal speakers turned off in order for audio to be output from rear jacks.
Dec 31, 2012 | Craig Electronics CHT912 Bluetooth TV...
Hook up sound bar to zenith plasma tv
If the sound bar has the red and white cable then yes you can use those. Make sure in your settings for the TV you have it set for an external audio source. Since you don't want to use the built in speakers. Probably best to get a tuner if using multiple speakers and a sub.
Dec 29, 2012 | Zenith Z60PV220 60-inch Plasma TV
No sound
When my sound output set to off and I use the remote to change volume; it tells me speakers off.
Try a different output method: hook up headphones, other speaker type... these answers should help you find a solution.
Feb 27, 2010 | Televison & Video
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
Speakers in pc mode
i have the same exact problem with mine i tried
(Start -> Control Panel -> Sounds and Audio-> Then in the speaker settings box click advanced -> then click the drop down bar and click monitor speakers.) it didn't help for me but you might find it help full..
Jun 17, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
196 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
