What kind of knee pads will be good to used for doing a roofing job I have bad knee and I need a good pair of knee pads to do the job with the more padding the better.
Rather than knee pads, if you can't stay on your feet, the foam from couch cushions are the way to go. They don't slide on asphalt shingles, and are usually free. Just scoot around on your back side. Be careful of it rolling up though.
its a bad connection on the air bag, happens over time and bumpy roads, lose connections happen, it will need to be removed and the connection fixed, this job can be difficult air bags are dangerous to fiddle with, you need to remove the battery ( remember you need the code for the radio and any other device that needs a code to work) negative lead and leave it disconnected for at min half an hour before even attempting to remove the airbag. there are videos on removing the air bags and in repair manual booklet. i would not recommend doing this by your self, have some one with you when doing this kind of job.
Knee pain is not a rare problem. It happens due to the tearing and wearing at the knee joint. Every one can have this problem, women are more prone to knee pain. To treat it effectively, the simplest way is applying cold compress because it can constrict the blood vessels and then reduce the blood flow coming to the pain area. as well as relieve the swelling.
Reference: Home Remedies for Knee pain- Authority Remedies
Yes But for that you need to follow these exercise if you are facing Knee pain:
1. Step-Ups
2. Partial Squats
3. Calf Raises
4. Straight-Leg Raises
5. Side-Lying Leg Lifts
6. Short-Arc Knee Extensions
no straight foward job remove front wheel and there is two bolts/allen keys (forget which) just undo one of them and the cali[er will move back then u need to pust the piston bake there is a proper tool but i have used a pair of mole grips before. regards
No but you need someone that can do a COMPLETE brake job. This means the rotors should be turned or machined to take out warps. You will hear all kinds of suggestions as to brake pads but I use a non-JAG pad but not ceramic. While ceramics have better stopping power they will also warp the disk faster and so you will not have as long lasting brake job
