Question about Alcatel OneTouch Fierce for MetroPCS Cell Phone
Phone calls r answer without me knowing it everyone hear conversation
Can't answer phone
Posted by lois reed on
When I call someone or thye call me I can barely hear them.
Hi there
The speaker of your phone has gone bad and the best solution is to get an expert to change it for you.
To solve the problem of everyone listening to your conversation while calling, you should connect a an earphone to your phone to use to make your calls.
Thank you for visiting fixya
Mar 06, 2010 | Motorola Mobility RAZR V3
How do I put second call on hold while finishing first conversat
FIRST U HAVE TO HOLD FIRST CALL. AND TAKE THE SECOND CALL.THEN HOLD SECOND CALL.FIRST CALL AUTOMATIC ACTIVATE.OK
IF HELPFUL THEN PLEASE RATE
Jul 10, 2009 | Uniden DXI8560-2 Twin - - Phone
Headset icon on nokia 6280
Have Her Make A Call Then Plug The Headphones In And Out 3 or 4 Then See If The Problem Persists.
Jan 14, 2009 | Toshiba Satellite 1400-S151 Notebook
ASSIGNING ANSWER TONES
i dont think it is possible but wil let u no if its possible
Dec 03, 2008 | Sony Ericsson Z750a Cellular Phone
Audio on h700c
Check to see if you have not muted the headset or the phone.
Nov 05, 2008 | Motorola Mobility Bluetooth...
Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off.  Try holding both volume buttons at the same time for a second or two.  If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Sep 29, 2008 | HTC Touch P3450 Smartphone
Callers say they cannot hear me
Yes it very well could be your phone lines and not the system. Call your provider and tell them you have low speech path on your lines. They will troublshoot it.
Mar 27, 2008 | NEC Electra Elite 32D-1 Corded Phone
No audio
Have you trie dputting your speaker volume up? When you start the conversation, just press the top left-side button on your phone and you should see the volume bars go up. I think this can only be done if you are actually on a call.
Mar 13, 2008 | LG Prada KE850 Cellular Phone
Blue Tooth Stereo Headphones and KRZR
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Dec 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Alcatel OneTouch Fierce for MetroPCS Cell Phone Logo
47 people viewed this question
Top Alcatel Cell Phones Experts
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
