Question about Kitchen Appliances - Others
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Posted by ivan svetelj on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Posted on Dec 26, 2015
Intermittent abs light, red warning light wont start some times in gear, and yesterday radio hand volume control would not work shut down let it sit started up and light were gone
Hi Tom, for more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at [email protected] Good luck and have nice day. Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 07, 2015 | 2014 Harley Davidson Electra Glide Ultra...
My electrolux vacuum has a red light that won't turn off and my brush roll won't work
Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
Aug 22, 2014 | Electrolux Vacuums
Philips food sealer kb1000
First you have to make a bag, so pull from the roll to the size you need, you might want to practice with a small one the first time.
Press the lid gently and the heat light should come on, when it turns green open the lid and you will have sealed one edge of the bag. (usually red means it is heating and green means it is finished)
To seal, place the bag over the vacuum nozzle to remove the air, usually pressing one corner starts the vacuum. When as much air is gone as you want, gently press the center of the lid again, and when the light is no longer red your bag should have the air gone and the bag sealed. DO NOT press too strongly on the center as that will cause the heated wire to cut the bag.
Mar 03, 2012 | Kitchen Appliances - Others
When I turn it on, it starts to hum but after 30 seconds the red light flashes and the intake/drain light is on. The Miele tech support says to take of the kick plate and empty check for a clog. Any...
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Perhaps Miele could send you one of those tools so you could try and see it the pump seal has swelled up and stuck.
Gene
Aug 12, 2011 | Miele Incognito G858SCVi Built-in...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
TURN ON CONSOLE AND 2 RED LIGHTS COME ON, OR IT COMES ON THEN FREEZES UP
how old is the xbox and does it still have a seal behind the faceplate? if its under 3 years and still sealed phone microsoft they will repair for free
Jan 23, 2010 | Microsoft Xbox 360 Console
My Seal-a-meal won't heat up to seal the bag. The motor works and the ''hands free'' light comes on, but the heating strip is cold to the touch.
just bought mine - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started, so I know it's "on"
Jan 08, 2010 | Kitchen Appliances - Others
Forgot how to put my Blueant in pairing mode. the
Turn it off, then when you turn it back on keep the power button (the green one) down until the blue light starts flashing red and blue.
Jun 13, 2009 | Blueant Supertooth Light Bluetooth Speaker...
2002 cbr 954 red light on gauge blinks
sounds like the engine management fault code signal. there is a free download service manual here. with it you should be able to decifer it http://www.carlsalter.com/motorcycle-manuals.asp
Apr 04, 2009 | 2002 Honda CBR 954 RR Fireblade
Kitchen Appliances - Others Logo
891 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
