KitchenAid 5KTT780E PRO-LINE SERIES 2 SLICE TOASTER FOR 220 VOLTS Logo
f
fabas pierre Posted on Dec 25, 2015
KitchenAid thermistor problems Toasters what is the thermistor reference merci
Kitchenaid superba ksra22fkss00 side by side fridge. The freezer temperature too cold.
Even though the freezer thermistor passes the test, it's bad. The test only sees if the thermistor is open circuit or grounded. These thermistors can send bad information to board. Replace the freezer thermistor and I think that will solve your issue. Good Luck
2helpful
2answers
Toaster
The Toaster have an electric plate for each side of toasting. So the right one is burn out and you need to replace it with new one
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Kitchen Aid Artisan 2 slice toaster, model 5KTT780 Blue light comes on but not as bright as usual, elements don't heat up.
Try pacific8's answer to this problem with another KitchenAid toaster, especially the comment on that answer by pacifics pam, all found here: http://www.fixya.com/support/t9655297-toast_will_not_stay_down_in_toaster_when
The freezer gets warm constantly and I must hit the tempature reset all the time how do i fix it Kitchenaid KSSC36FMS
HI, this unit is equipped with with a thermistor that runs to the control board. you may have some issue here. have the thermistor inspected.
The thermistor is the principal temp regulator that relays the temp information to the main board.
1helpful
2answers
Right side stopped working (KPTT809)
I had the same problem with my Kitchenaid toaster which is 4 years old. I called Kitchenaid and they said that this model now has a 5 year warranty and they have replaced the toaster for a new one. What a fantastic company. Try giving them a call.
Left two slot elements don't work. this is the second one with the same problem. both times the left side stopped working after 3 or 4 uses.
Kitchenaid Pro Line appliances do carry a 2-Year Hassle Free warranty with them. While I cannot provide an accurate description of why this problem occurred, there is a good chance they will be able to exchange it for you under the Pro Line Warranty. Please contact Kitchenaid Customer Service.
Their toll-free phone number is 1-800-541-6390.
1helpful
2answers
KitchenAide Toaster
Kitchenaid does not recommend repair on the toasters, as it is not cost effective for the consumer or company to engage in repair.
I would recommend calling Kitchenaid Customer Service. If the unit is within the 1 Year Warranty, they may replace it at no cost. If the unit is outside of warranty, they may provide discounts on the purchase of a new toaster.
Their toll-free telephone number is 1-800-541-6390.
Four slot toaster two ok go to use the four it blows a fuse need to find a service centre.
A list of Kitchenaid certified repair facilities may be found at the following link:
http://caservice.kitchenaid.com/
There, you may narrow centers down by state to the find a certified Kitchenaid technician as close to you as possible.
Top KitchenAid Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
