sounds like you have no water coming in...pull the line..make sure u got water..vacuum out the back fins and bottom so theres no dust or build up on the cooling fins..clean the inside..plug it in and try it..
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Your condensate drain line is stopped up. Break the ice up off the freezer floor with a screwdriver handle. Turn off the refrigerator. Remove the back inside panel from the freezer. Break up the ice in the drip pan with a plastic handle. you can either heat up a wire with a torch and stick it in the drain to thaw the ice in the drain or set a hair dyer in the freezer until the ice melts in the drain. Then find a 4' piece of 3/8" tubing to stick in the drain and blow in the other end to remove any trash in the drain. you can use compressed air or weed eater line. anything that will clear the drain
The most common problem is the defrost drain hole is plugged or frozen over.And the defrosted water from the evap coil is leaking in the fridge compartment,You may have to remove the back panel in the freezer compartment and defrost the evap coil and drain area.
this sounds like a control board circuit problem..but first remove perishables and defrost freezer ..turn off or un plug..leave refr door closed..freezer door open..if you have lots of water while defrosting you almost cirtainly have froozen the evap coils solid..freezer cannot work like this..after defrost..plug in and see if temperature returns to normal..if it does it won't last indefinately..your probably have a bad defrost timer and/or evap heater gone bad
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
The coil in the conditioned space is called the evaporator.
If the water droplets are forming on the ceiling around the evap, it is due, most likely, to the defrost cycle being too long.
Defrost cycle: compressor stops, evap fans stop, electric heaters in the evap come on to clear any ice/ frost on evap fins/ coil.
The ice/ frost melts and some of it turns into vapor. As it hits the cold ceiling surface, it condensates into water droplets. Defrost cycle could be too long. Usually 4 time aday and no longer than 30 minutes should be enough unless there is high humidity.
There could be another cause.
Normally, after a defrost cycle terminates, the evap fans do not come on, due to a delay control. This prevents circulating warm are due to the heaters. The compressor comes on and cools the evap down to, usually 20 degrees or so, and then the fans come on. What could be happening is, the fans are coming on too early and blowing the water driplet off the evap and onto the back wall of the unit.
A third item, is to be sure that the condensate drain is "P" trapped. The prevents warm, outside air from being drawn in and causing exess frost build up, thus excess water and vapor.
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
We bought a Kenmore Elite Trio 596.76533500 from Sears in 2006. A few months passed and the Elite broke down. The tech person came out and found that the AC Evaporative Fan was inoperable. It was replaced (part #67003917). A few months later the same thing happened. But before they came out, I spoke to the tech person on the phone who seemed very familiar with the fan. He said that they've had numerous problems with that fan model and would bring out an older-type one that had fewer sensors and that was less prone to failure. The "motor evap" part #2214986 (Whirlpool compatible) was put in and everything has been working since... Hope this helps...
