Question about Ovens
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Posted by Annette Bracamonte on
Claude Kayser
    Top Expert:
  • Ovens Master
  • 9,098 Answers
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Posted on Dec 25, 2015
5 Related Answers
eagle338
eagle338
  • 4889 Answers
SOURCE: amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Oct 17, 2007
Anonymous
  • 234 Answers
SOURCE: Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Posted on Apr 27, 2009
Dave Harrison
  • 114 Answers
SOURCE: Our Maytag Oven keeps flashing F7 and beeping we
Contained within the oven, usually behind the backgurad, there is a tech sheet. DISCONNECT POWER and pull off back panel behind backguard to locate sheet. Within this sheet there are a list of fault codes and the corrective procedure.
Posted on Aug 24, 2009
Anonymous
  • 31 Answers
SOURCE: F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Posted on Jun 22, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: GE Profile Double Oven F1 Error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&*&^%rt
Posted on Oct 01, 2010
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
Maytag electric range, older model. What is a beeping, flashing code F2
F2- oven too hot. usually due to a bad oven temperature sensor. they sense the temperature of the oven by changing resistance, and can keep the element hot, or turn it off.
Jul 06, 2011 | Maytag Ovens
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Our Maytag Oven keeps flashing F7 and beeping we tried to push cancel and nothing happened so we have turned the power to the oven off. What do we need to do to fix it?
Aug 24, 2009 | Ovens
Apr 27, 2009 | GE Ovens
Wall unit oven keeps beeping
There may be also a code that flashes on the oven switch display. My Frigidaire stove started beeping and flashing F-1 at me repeatedly. This indicates a problem with the circuit board. Well, the convection switch was an external momentary contact switch, and it was sticking in the on position, which was apparently the source of the problem. This type of problem can also be caused by a voltage surge, in which case you will probably have to replace the oven switch.
It could be the clear button, or any other button that is getting stuck. These older computers used microswitches, and they are certainly subject to getting stuck.
They are expecially prone to voltage surges, however, and since my power company is one of the worst I have seen in my life, I was afraid that this was the source of my problem. If you were hit by a surge you might have to replace the switch, and on an oven this old, you might have a problem obtaining one.
Your local Sears store might have a clearance oven that they would be willing to sell you cheaply--the same goes for any other store that sells appliances. You should consider that this oven could cost you hundreds of dollars to fix if you can even fix it, so it might be worth your while to replace it. A new oven would have more features, and would have a nice clean interior, and look a lot more modern as well.
Feb 09, 2009 | Stainless Ovens
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 | Ovens
Message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Apr 19, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
340 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
