My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
  • Televison & ... Master
  • 5,638 Answers
Restore Deleted Data from Samsung
Here I'll introduce you Android ToolKit - Android data recovery to restore deleted data from Samsung, which has been widely accepted as the best recovery tool to recover deleted data from Samsung Android phone selectively. By using this tool, all deleted contacts, messages, call history, videos, photos, documents, WhatsApp messages, and more will be deeply scanned and recovered from your Android device. You are allowed to preview the data before recovery.
Additionally, this program enables to extract data from broken Android device, backup & restore Android on computer safely. Compatible with almost all Android models, such as, Samsung (Galaxy Note 9/8/5/4, Galaxy S10/S9/S8/S7/S6), HTC, Lenovo, Huawei, Google Pixel, LG, Sony, OPPO, OnePlus, ZTE, Xiaomi, etc,.
LEARN MORE
Android Data Recovery Software How to recover deleted and lost data from Samsung on Mac How to recover deleted and lost data from Samsung Galaxy J1 J2 J3 J5 J7 How to recover deleted and lost Contacts from Samsung Galaxy J1 J2 J3 J5 J7 How to recover deleted and lost SMS from Samsung Galaxy J1 J2 J3 J5 J7
Posted on Jul 09, 2019
    Top Expert:
  • 9,098 Answers
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Posted on Dec 25, 2015
Sharp LC-32lb261u TV no longer works after a thunderstorm. If I unplug it & then plug it right back in, I get several random flashes of the red power light.
Sorry for the inconvenience. Actually the LED flashes indicates a code. Could you provide how many times it flashes and the pattern?
For example: 8 short 3 long or 7 flashes and repeats.
Jul 28, 2018 | Sharp Televison & Video
My JCV flatscreen turns itself off randomly, what could the prob
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 12, 2015 | Televison & Video
Samsung la32s81b
Probably the power supply is failing or has failed.
Oct 24, 2017 | Televison & Video
Some time ago, I was watching TV, then, all of sudden, the TV screen has gone, just like 'blank'. The main power (red light) keeps on blinking. Normally, it is just on, not blinking. TV doesn't respond at...
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Bush 5693D 24" TV
Sony KDS-60A3000 turns off by itself and red light flashes 3 times
the flashing light is more than likely the fault code. but those can be wrong bet even money that the door has a sensor to know if its open and the the bi-metallic switch is on the fritz look around the door see of the is a small pressure actuated switch the opens and closes with the door if so all else checks out 85 % chance that will be you problem
Dec 02, 2013 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
Televison & Video Logo
920 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
