Question about GE Profile PSI23NCR Side by Side Refrigerator
How do I remove water drop on light cover? - GE Profile PSI23NCR Side by Side Refrigerator
Posted by George Greene on
I dropped the speaker in water yesterday. I turned it off & attemped to dry out now it won't charge.
You toasted your battery. Unfortunately, you are more than likely out of luck as water damage is not covered under the Bose warranty.
The next time, hopefully never again, you drop an electronic device in the water, DO NOT TURN IT ON! Remove the battery and let dry for 48 hours, with all possible covers removed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_101fbc448ddafa3d
tip
How to repair your Mobile when it dropped in water?
<p><span>If you worry as your mobile phone drop in water. It may happened by rain or else. However, there is no need to panic. You can save your mobile by repairing it.</span><br /> <p><span> </span><br /> <p><span>. Quickly open all cover part as possible such as the cover, SIM card, memory card battery, etc</span><br /> <p><span> </span><br /> <p><span>.Take a piece of dry cloth or tissue paper for removing the water. If you sure that dry it completely, or some inside part out of your reach.</span><br /> <p><span> </span><br /> <p><span>. You can use a hairdryer and begin to drying the mobile by put it in the place where battery is located, and keep it too close to the mobile it may harm the electrical mechanism of the mobile phone. </span><br /> <p><span> </span><br /> <p><span>. Keep the mobile phone in sun light or in warm place for twenty to thirty minutes.</span><br /> <p><span> </span><br /> <p><span>. You may take off the covers and battery from the mobile phone. Keep the mobile in a dry or warm place to remove the water from the mobile phone. </span><br /> <p><span> </span><br />
on Dec 24, 2010 • Cell Phones
How to change the water filter on kenmore refrigator 79570323310
On the 79570323310, you first need to lower or remove the top shelf from the refrigerator. This will allow the water filter cover to drop down out of the way. Press the button on the front of the cover to release the cover and drop it out of the way. Next pull the water filter down completely before you pull it towards yourself to remove it from the manifold hole in the water filter housing. You may want to put a cup under the water filter cover while it is down to collect the water that will come out with the filter. Next remove the new filter from the carton and remove the protective filter. With the tabs on the filter held horizontal, push the new filter into the manifold hole at the same angle as the old one came out. Then push the front of the filter up until it is flat at the top of the refrigerator. Finally push the water filter cover up until it latches closed.
Sears Parts Direct has the manuals for many of their appliances online, the manual for the 79570323310 is here: http://www.searspartsdirect.com/partsdirect/user-manuals/79570323310-kenmore-parts-REFRIGERATOR-manual .
I hope this helps.
How do I change a 2001 ford taurus timing chain cover gasket?
Pretty tough job,,if you dont work on cars much..You have to remove the water pump,,and also alot of the accessories around the water pump..You also have to drop the front of the oil pan down ,,to remove the timing cover..I always like to remove the oil pan and replace the gasket on it as well...
8helpful
How to change water pump on 1999 alero 2.4 liter twin cam
REPLACE WATER PUMP ON A 1999 OLDSMOBILE ALERO. FIRST YOU HAVE TO DRAIN COOLANT SYSTEM IN A LARGE DRAIN. RADIATOR DRAIN PLUG SHOULD BE ON THE BOTTOM ON PASSENGER SIDE. THEN RAISE THE VECHICLE SUPPORT VECHICLE WITH JACKSTANDS. REMOVE THE EXHAUST MANIFOLD FROM THE ENGINE. CAUTION DO NOT ROTATE THE FLEX COUPLING ON THE FRONT EXHAUST PIPE MORE THAN 4 DEGREE OR DAMAGE TO THE FLEX COUPLING MAY OCCUR. REMOVE THE THERMOSTAT AND THE COOLANT INLET PIPE FROM THE WATER PUMP HOUSING AND SEPARATE THE ASSEMBLY FROM THE ENGINE. LOWER THE VECHICLE REMOVE THE BRAKE BOOSTER VACUUM HOSE FROM THE CAMSHAFT HOUSING. REMOVE THE FRONT TIMING CHAIN COVER AND THE TIMING CHAIN TENSIONER FROM THE ENGINE. CAUTION THE TIMING CHAIN TENSIONER MUST BE REMOVED TO UNLOAD CHAIN TENSION BEFORE REMOVING THE WATER PUMP FROM THE HOUSING OTHERWISE THE WATER PUMP WILL BECOME JAMMED IN THE TIMING CHAIN HOUSING. REMOVE THE HEATER OUTLET PIPE FROM THE WATER PUMP COVER. REMOVE THE WATER PUMP COVER BOLTS FROM THE ENGINE BLOCK AND THE WATER PUMP. REMOVE WATER PUMP RETAINING NUTS AND SEPARATE THE WATER PUMP FROM THE TIMING CHAIN HOUSING. CLEAN THE SEALING SURFACES OF ALL GASKET MATERIAL ON THE WATER PUMP, WATER PUMP COVER AND THE TIMING CHAIN HOUSING. WIPE THE MATING SURFACES WITH A RAG SATURATED LACQUER THINNER OR ACETONE. YOU CAN BUY THESE CHEMICAL AT LOWES OR WALMART DEPARTMENT WHERE THEY SELL PAINTS. FIRST INSTALL THE WATER PUMP COVER AND GASKET TO THE WATER PUMP ON THE BENCH BUT LEAVE THE BOLTS FINGER TIGHT. APPLY A THIN LAYER OF RTV SEALANT TO BOTH SIDES OF THE NEW GASKET AND INSTALL THE GASKET ON THE WATER PUMP. WAIT FOR RTV SEALANT SET UP DRY FIRST. POSITION WATER PUMP AND WATER PUMP COVER ASSEMBLY INTO TIMING CHAIN HOUSING ENGAGING THE WATER PUMP SPROCKET IN THE TIMING CHAIN, AND INSTALL THE NUTS FINGER TIGHT. USE CAUTION TO ENSURE THAT THE GASKET DOESNT SLIP OUT OF POSITION. LEAVE THE NUTS LOOSE TO ALLOW REPOSITIONING WHEN THE BLOCK BOLTS ARE INSTALLED IN THE NEXT STEP. INSTALL THE WATER PUMP COVER TO ENGINE BLOCK BOLTS AND TIGHTEN THEM BY HAND. LUBRICATE THE O - RING ON THE HEATER OUTLET PIPE WITH COOLANT AND INSTALL IT INTO THE WATER PUMP COVER. HAND TIGHTEN THE BOLTS. NOW THAT THE ENTIRE WATER PUMP HOUSING ASSEMBLY IS INSTALLED AND IS FITTED AGAINST THE ENGINE BLOCK. TIGHTEN BOLTS CRISS CROSS SEQUENCE TO INSURE PROPER SEAL TORQUE WATER PUMP TO TIMING CHAIN HOUSING NUTS TO 19 FT LBS .NOW TORQUE WATER PUMP COVER TO WATER PUMP HOUSING BOLTS TO 124 INCH POUNDS. TORQUE WATER PUMP COVER TO ENGINE BLOCK BOLTS 19 FT LBS. TORQUE 124 INCH POUNDS THE RADIATOR OUTLET PIPE TO WATER PUMP HOUSING. INSTALL THE TIMING CHAIN TENSIONER AND COVER. INSTALL THE EXHAUST MANIFOLD. INSTALL THE EXHAUST PIPE TO THE EXHAUST MANIFOLD. WHEN ALL IS DONE. START POURING COOLANT IN THE RADIATOR OR COOLANT OVER FLOW JUG.CHECK FOR LEAKS. IF IS GOOD KEEP ADDING COOLANT TO RADIATOR OR OVER FLOW RESERVOIR UNTIL COOLANT LEVEL STOP DROPPING. NOW START ENGINE. WATCH THE COOLANT LEVEL WHEN START DROPPING ADD MORE COOLANT IN RADIATOR OR OVERFLOW JUG. WHEN COOLANT STOP DROPPING INSTALL RADIATOR CAP OR OVERFLOW JUG CAP. LET ENGINE IDLE UNTIL THERMOSTAT OPENS WATCH TEMPERATURE GAUGE WHEN TEMPERATURE GAUGE RISING TO OVERHEATING. TURN OFF ENGINE WAIT A WHILE TAKE A LARGE RAG SLOWLY OPEN RADIATOR CAP A LITTLE TO RELEASE PRESSURE. WHEN PRESSURE RELEASE REMOVE RADIATOR CAP ADD MORE COOLANT. START ENGINE LET IDLE WATCH TEMP GAUGE. TEMP GAUGE START RISING AGAIN TURN OFF ENGINE LET IT SET A WHILE ADD MORE COOLANT. TO RADIATOR. WHEN ENGINE TEMPERATURE GAUGE STOP RISING AND THERMOSTAT OPENS YOUR COOLANT SYSTEM AIR IS BLED OUT. JUST LET VECHICLE SET A LITTLE CHECK COOLANT LEVEL MAKE ITS CORRECT BEFORE START DRIVING VECHICLE. IF YOU TAKE VECHICLE FOR TEST SPIN TAKE LARGE RAG AND PLENTY COOLANT WITH YOU.IF ENGINE START OVERHEATING WHILE DRIVING PULL OFF ROAD SAFELY WAIT 20 TO 30 MINUTES. USE LARGE RAG SLOWLY OPEN CAP A LITTLE RELEASE PRESSURE. THEN REMOVE RADIATOR CAP ADD MORE COOLANT IF NEEDED. HOPE THIS HELP.
How to remove and replace water filter on a french door/bottomn freezer frig?
filter should be in upper right hand corner there should be a drop down tap that will drop down that cover that hides the filter once dropped down u will see filter u can remove it be turning it out ,,,,,,there is no need to turn off water supply as unit does it internally,,remove filter probably a ukf8001, look for a part number on it and purchase one most local appliance stores would stock that filter,,,replace it and u should be set hope this helps
2helpful
How to clean filter
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
1helpful
I dropped it in water
You may have shorted it out. Take back off, remove battery and sim and dry it out as best you can leave it in an airing cupboard or warm place to dry out overnight. Put it back together and hope for the best. If you can easily remove the front cover and keypad remove that as well. Just cross your fingers!
2helpful
WHIRLPOOL DUET MODEL GHW9150PW1 doesnt complete wash cycles
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
GE Profile PSI23NCR Side by Side Refrigerator Logo
Top Refrigerators Experts
Vish Iyer
Vish Iyer
Bill Dakelski
Level 1 Expert
