Question about iRiver H320 MP3 Player
Dropped the player, now I have a blank screen
I tried to remove the HDD and put it back, same result. Tried to connect to the computer via USB, no change. HDD makes no sound,I can't tell if its dead or the mother board crashed.
2 Related Answers
Anonymous
SOURCE: Check hdd connection
Had the same problem from above and yet no luck
Posted on Jan 03, 2008
Anonymous
SOURCE: mp3 player
How Do you suppose to reboot a digital audio mp3 wma player from a computer?
Posted on Dec 03, 2009
Toshiba satellite l305-s5933 computer stuck on the Toshiba leading innovation screen. it have the option to press F2 or F12, but it don't work
Try removing the hard disk and check if after removing HDD is must show "Boot Device Not Found" , if it shows the same it means your HDD is faulty or loose connect try reconnecting it , if remain same replace the HDD. This problem happen in common due to HDD failure as system keep on trying to detect the connected HDD but unable to detect it.
Jan 30, 2015 | Toshiba Computers & Internet
My Sony Cybershot DSC-W215 no longer connects properly via USB. I've tried it on a different computer with the same result. The screen on the camera just says USB Mode Connecting. Switch on [Menu]. I've...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 18, 2011 | Sony Cameras
I have an old hp desktop 8570c. I tried using a product called a ''Tornado'' to transfer files to another computer. It didn't work. Now when I plug in my computer (hp 8570C), it simply runs with the busy...
If I were you I would remove the HDD from the computer and place it in an external enclosure, and then connect it via usb to another computer. This will allow you to retrieve the info you need. As for getting that computer back up and running, once you remove the files you need replace the HDD back into the system and reformat using the recovery CD's
Feb 08, 2010 | Computers & Internet
When i turn on console nothing happens either i get a blank screen or the wavy screen before the icons pop up
There are two things you can try:
1) First try the following: Switch the PS3 off (Red Light). Hold your finger on the power button until the PS3 switches on and off. Take your finger off and hold it in again. It will come on. Hold it until you hear a double beep and take it off immediately. You will then be taken into a recovery menu. It will ask you to connect your controller via USB. Choose option 3 - Restore File System (Do not try any other option as it will erase some or all data on your HDD) It will also give you a message that the file system is corrupted. Just go through it and continue the restore.
2) Put another HDD in the PS3, format it when prompted and you will have the XMB back. Now remove the HDD and put your old one back.
Hope it helps
Aug 03, 2009 | Sony Playstation 3 (PS3) Console
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
Can't see Sumvision Cyclone HDD on PC
see this link
http://docs.google.com/Doc?id=dgcfqncj_0cnqvx5gt
Jan 27, 2009 | Sumvision Sempra PRO Digital Media Player
Screen Blank- can't even reset
thats what happened to my ipod there really isnt anything you can do. i really know how you feel sorry!
Dec 30, 2008 | SanDisk Sansa e260 MP3 Player
3 long beeps of my elitegroup ecs green 320
If you cangatehr this much of information you are no less than a computer engineer. Nobody needs to build a car to change its tyre. If you arrange a spare HDD and RAM, remove the original HDD and try to install windows on that. And if problem persists do the same with RAM also. I am sure you could solve this problem yourslef.
Oct 06, 2007 | EliteGroup ECS G900 Notebook
White screen
Remove the battery. Take a small pointed object such as a toothpick and press down on the tiny gold dot that says reset. Put the battery back onto the unit and power it back on. Hopefully that helps. If the unit powers back on and asks you to repair the hard drive. Select option one and do not turn the unit off until it is finished. I recommend connecting the unit to your computer via USB to keep it powered on in case of battery failure. If the HDD repair is interrupted, it is possible to completely ruin your unit. Good luck!
Sep 20, 2007 | Archos 604 Digital Media Player
iRiver H320 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Jean Sintulaire
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
