My phone blacked out and won't turn on even when I put it on the charger. It seems to be totally dead. How can I fix it?
SOURCE: My Samsung phone has no power, won't accept a
The battery is most likely at fault, though if a different battery still doesn't work, there's probably something else to blame.
SOURCE: how to splice samsung galaxy s cell phone car charger to wall charger
you should just do white to white and ref to red. just so you should know that ac chargers have a special crossover that the phone knows it is charging not usb' ing to a computer so you may get message on the phone to go into usb mode...just hot home and you well be fine
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
SOURCE: My Samsung galaxy s phone won't play any videos
,U shud convert the video files first in the supported format of ur phone..read the manual to see which formats are supported..th,,,,,,,,,,,,,,
SOURCE: samsung galaxy s2 dead and i cant even turn on my phone
If you've got your phone brick try to put it into "restore" mode: <vol-down>+<home>+<power> and keep them pressed until you see restore screen. If that didn't work try to <vol-up>+<home>+<power> - you'll go to "download" mode. If that works then you're lucky and you'll be able to restore your phone. Give me a private shout @ [email protected] I'll provide you detailed instructions.
