Re: 601 Ford Tractor fuel shutoff leaks. Is there an...
If it is the old slide across to shut off tap used on petrol engines there is an o ring that can be replaced
if not ,any turn fuel tap will fit in it's place
COULD HAVE DAMAGED RUBBER O RING TIGHTEN TOO TIGHT OR REUSED THE OLD ORING WILL CAUSE LEAKING.IF YOUR THERMOSTAT HAS PAPER GASKET INSTEAD O RING. YOU NEED TO PUT SEALANT ON BOTH SIDES OF THE GASKET.THAT WILL KEEP IT FROM LEAKING.IF YOUR VECHICLE HAD A RUBBER O RING AROUND THERMOSTAT REPLACE WITH NEW O RING DONT PUT PAPER GASKET IF YOU HAVE THE O RING SEAL.THE O RING DOES THE SEALING NO NEED PAPER GASKET.
sound like you have a leaking head gasket , or possible oil rings on the pistons are worn, if you have the head gaskets replaced check the clearance for the oil rings , mechanical shop can do this , just let them know to check them , but i would start with replacing head gaskets , if the smoke it white then you are leaking coolant into the cylinders , either way the head gaskets will fix
Recheck the o-ring on that injector, the one up at the fuel rail to make sure it didn't get damaged.
Try and seat the injector into the fuel rail first, then push it gently into the manifold, ( that is if you haven't already did that).
REPLACE VALVE COVER GASKET AND O-RINGS AROUND EACH HOLE INSIDE VALVE COVER TO PREVENT OIL FROM ENTERING. LEAKING FROM SEALS AROUND VALVE COVER TO SPARK PLUG PORT GASKET OR O-RING
To gain access to the fuel pump, it is necessary to remove the fuel tank.
Depressurize the fuel system and remove the fuel tank from the vehicle.
Remove any dirt that has accumulated around the fuel pump module
attaching flange, to prevent it from entering the tank during service.
Turn the fuel pump module locking ring counterclockwise using a
locking ring removal tool or a brass drift and remove the locking ring.
Remove the fuel pump module.
Remove the seal gasket and discard it.
To install:
Put a light coating of grease on a new seal ring to hold it in place during assembly. Install it in fuel tank ring groove.
Insert the fuel pump module into the fuel tank, then secure it in place with the locking ring. Tighten the ring until secure.
Install the tank in the vehicle.
Install a minimum of 10 gallons of fuel and check for leaks.
Install a pressure gauge on the throttle body valve and turn the ignition
ON
for 3 seconds. Turn the key
OFF
, then repeat the key cycle five to ten times until the pressure gauge shows at least 30 psi.
