But surprising the disk is seen in the bios when you go to setup. please help me to unravel this strange fault. thanks
Top causes on all PCs (desktop only)
NO PC model told the service tag on any of 6 sides tells what it is.
there are 3 ways to test any HDD.
A: move it to a good PC on 2nd Sata port and test it.
B move it to 2nd PC and use USB to SATA docking bay and test it.
C: boot the dead PC, to linux and run disk check
A or B
use ,free and 100% safe.
https://www.passmark.com/products/diskcheckup/
C: use Ubuntu demo media (DVD or USB thumb drive) 100% safe.
https://www.pcdied.com/linux.html
NO PC told.
the coin cell must be not below 2.9vdc or is bad,
2.9vdc is the point of "deathh cliff" EOL. (sic)+
or run the HP diagnostics, how to , can only be answered with HP real service tag model # and product ID.
off the tag;.
HP.com will demand the same thing , due to being blind.
SOURCE: When i turned on my laptop(Toshiba Tecra 8000), only a black screen appears and a note
what are you using a dos floppy ? lol i use a bootable live cd gparted-live-0.3.6-7.iso
SOURCE: hard drives not detected in my hp compaq nx6310....
Dear, in all the new laptop's its common problem because what bootable cd u are using did not contain sata drivers and thats why it shows no harddrive found ok so search the sata drivers and make bootable cd by adding this sata drivers and than try to boot.
SOURCE: 1790: disk 0 error
Your hard drive has failed to load.In the bios did it show the hard drive?Can you hear the hard drive?Do you hear a clicking sound?The are signs that the drive is failing.Try to boot to a windows cd, see if this will allow you to see the hard drive.If you can chances are you might be able to get your data from the drive.Once you do so replace the drive.
Good luck
SOURCE: my boot screen shows secondary slave hard disk
Check on harddrive you find jumper on it.
Then read on harddisk you can find there is specifiaction for master, slave and cable select jumper settings.
Put jumper as cable select then check.
Also reconnect sata or ide and power cable to harddisk.
Then check .
Let me know if you need more assistance.
Thanks.
SOURCE: HP 8GB pen drive is detected as removable disk in
when i insert pen drive. the computer does not any response. plz help me in this regard plzzzzzzzz
