Question about LG WM-1832C Front Load Washer
Intellowasher WM-1460 FHD
Cycle stopped, half full with water and is flashing OE at me any ideas? thanks.
Posted by bikkle on
  • Anonymous Mar 12, 2014
    my bush wm-1460 keeps showing error 7 what does this mean
Anonymous
I have the same, and sometimes coins get past the drain filter into the pump.
If cleaning the drain filter does not fix then drain the unit tip it on edge and unclip the pump from bottom after taking screws from front (clip on bottom lests you slide it back) then shake out the coins, you do not need to detach the rubber tubes from pump
I have had to do this a few times.
T
Posted on Nov 18, 2007
Anonymous
  • 18 Answers
Try cleaning out the drain filter and see it that fixes it.
Posted on Nov 17, 2007
Flashing power and cycle light.
try a different cycle but suspect the timer has failed .
Apr 12, 2015 | Washing Machines
OE error Kenmore washer?
download the user manual from the manufactures website ite normally free to download eric
Dec 24, 2017 | Washing Machines
Flashing six setting modes and won't turn off.
DONOT START MACHIN BUT BECOM FULL WATER AND ERROR OE
Apr 04, 2013 | Dishwashers
My Candy C514 Washing Machine stops half way through the cycle and lights flashing.Yesterday mechanic came and checked everything ok Motor, pump and water goes in fine, any idea? What this can be? Many...
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
Jan 19, 2011 | Candy Washing Machines
Machine won't spin and rinse and stops with an "OE" message.
it could be as simple as a wire has come off the pump during transport or the pump was about to die.
check if wires have come off pump and if ok then with a little water in the machine see if you can blow some air back down the drain hose to see if there is a blockage in the hose or the pump if there is you will have to remove the hoses from the pump and clear the obstructions
Jun 11, 2009 | LG WM2688HWM TROMM SteamWasher
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
NEC washing machine won't spin. Letters OE flashing
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
LG WM-1832C Front Load Washer Logo
219 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
