Ice is not being loaded into the ice cube reservoir
This is not difficult to troubleshoot.
The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
