Question about Olevia Televison & Video
How to do a complete initial setup on olevia 542-b11
    Top Expert:
  • Olevia Master
  • 9,098 Answers
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Posted on Dec 22, 2015
I need the Manual for the Olevia 537-B11 TV
Try Googling (olevia)(537-B11)(manual) without parens.
May 29, 2017 | Olevia Televison & Video
542-b11 will it work with digital antenna
Refer its user manual [specifications] and see whether the tV can process digital signals. If it has ditgital processor inside, you can see it there in its specifications.
Apr 27, 2012 | Olevia LT42HVi 42 in. LCD Television
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
In need of a owners manual for a model 542b11 42 in Olevia brand TV
I have the users manual. Leave me your email address and i`ll send it to you, it is about 6 megs in pdf format.
Dec 02, 2009 | Olevia LT42HVi 42 in. LCD Television
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Sep 10, 2009 | Olevia Televison & Video
I have an Olevia 542-B11 TV with remote control. I have Directv and always had to use (2) remote controls. My dog chewed my Olevia remote control, now I can't turn the TV on or off, adjust volume, switch...
its hard to find a remote that will work an olevia , since this brand is new and alot of manf. that make universal remotes have not updated there system..
This company called Amergence Technology sells the Olevia Remote and will control any olevia television.
Contact them at 866-965-3842 (just ask to purchase a remote)
Jun 29, 2009 | Olevia LT42HVi 42 in. LCD Television
Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Jan 21, 2008 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
262 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
