Question about Samsung Refrigerators
Model RB215LABP reset temperature display after power outage
Posted by Sandy Schlecht on
Claude Kayser
    Top Expert:
  • Samsung Master
  • 9,098 Answers
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Posted on Dec 22, 2015
I have a Samsung refrigerator model RF323TEDBSR that after power outage is flashing 33 E. I have tried unplugging and replugging & pressing power freeze & power cool at same time, still nothing.help?
The 33E error can indicate a problem with the ice maker water fill tube heater. (This makes sure that ice doesn't form and cause the fill tube to break.) To attempt to reset the error, press and hold the Energy Saver and Lighting keys on the touch pad for 8+ seconds. These are the top buttons on each side of the temperature display.
If that reset doesn't help, you need to replace the left door. That is available here: http://www.searspartsdirect.com/model-number/rf323tedbsraa0001/1482/0161000.html . It's part 1.
I hope this helps.
Aug 21, 2016 | Samsung Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Frigidaire GLHS269ZCB4 after power outage Freezer not cooling fridge warmer hear the fan click and short cycle
Hello Wayne, thank you for allowing me to assist you. Was the freezer unplugged during the power outage? If it was, here are some simple troubleshooting steps you need to take:
It is best to unplug the unit and wait for the power to come back on.
Next, turn the control to off (or digital display), plug the unit in and reset control to factory-suggested setting.
Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the refrigerator plug is tightly pushed into electrical outlet and not plugged into a GFI.
If your unit has no power and it is not due to a power outage, check the following:
Verify that the temperature control is set to the OFF position.
Set temperature controls to proper setting suggested by your owner's guide; or set to the halfway point and adjust it up or down as needed.
If these basic troubleshooting tips prove ineffective, the power loss may have possibly caused a communication problem with the control board, temperature control or wiring harness. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Aug 23, 2013 | Frigidaire FRS26KR4A Side by Side...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
My Oaisis II hot tub stays at 103 and now it's dropped down to 68 degrees for the past 3 days? Could there be a problem with my heater element? Or is there a sequence of resetting the temp buttons on top...
Information on the care of your product and troubleshooting is available here:
http://www.oasisleisure.ca/customer_care/SpaCare.html
Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
Some possible causes and actions are:
Pull filter (see if light comes on) / Replace filter
Knife valves not fully open / Open knife valves
Pressure switch cut of calibration / Adjust pressure switch
Faulty Pressure Switch / Replace pressure switch
Air leak, check pump suction line / Tighten pump union
Heating element corroded / Replace element
Faulty control panel / Replace panel
Find the Manual for you specifc model for more explansyion on Troubeshootig.
Feb 06, 2011 | Home
Malfunction detected, please call Tech Rep. C3451
Here's the reset procedure.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
And yes, a power outage could cause this.
Jun 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Default temperature settings
if it is anything like a monitor - look on the right side bottom for a slider - reset temperature adjust. just move the slider to a lower temperature. if you have a power outage, the display starts to flash 88:88
Dec 15, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Refrigerators Logo
1,633 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
