My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
SOURCE: daihatsu Charade engine problem!
Check the engine faukt codes. It could simply be a coolant sensor that has gone dud:
here
SOURCE: 02 dodge dakota 4.7 v8 starts then dies when cold
Have your battery tested. It might have a bad cell causing it to not have enough "COLD" amps of cranking power.
SOURCE: 1996 Dodge Ram 1500 4x4 5.2L engine. Truck stalls
Hi, I have the same problem, I'm sorry I can't help, but if you figure it out please let me know.
SOURCE: Engine heats up but takes a long time for warm air
low fluid level or heater control valve may need replace..check hoses going to heater core...if cold...between heater control valve and heater core..replace control valve
