Question about Whirlpool Dishwashers
Assuming the lights come on, the pump likely has gone bad and needs to be replaced. I had the same thing happen a few years ago on my Quiet Partner II, and replacing it solved the problem. I was able to find one online for $20-30 and do the job in under an hour.
Posted on Dec 30, 2015
SOURCE: water will not fill into dishwasher
hi, it could be the inlet valve. This is usually what the hose fits to on the outside of the machine, and on the inside is the valve. MAKE SURE THE POWER IS OFF BEFORE you take the wires off the valve, then check for a reading on a ohms meter.ACROSS THE TWO TAGS, If no reading on the meter, the valve is gone. Regards, Tom.
Posted on Apr 06, 2007
SOURCE: whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Posted on Feb 19, 2008
SOURCE: Whirlpool DU1055XTP dishwasher fills with water but won't wash.
Can you be more specific? Does the dishwasher fill and then overflow?
Posted on Apr 11, 2009
SOURCE: whirlpool dishwasher adp4407 wont start
be sure the door is shutting properly the door switch may also be bad
Posted on Apr 24, 2009
SOURCE: I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
whirlpool gold starts the soaking time but dosnt run after that the time remaing light just blinks
Posted on May 01, 2009
Aug 18, 2014 | Dishwashers
Nov 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Hi
When the Dishwasher won't fill you'll need to
check for the water inlet hose, the water inlet valve and the float switch
assembly. When the water fills your dishwasher, a float rises along with it. As
the float reaches a certain threshold level, it shuts off the flow of water,
thereby preventing a leak. Sometimes the float can get stuck in the wrong
position in your dishwasher, and it can prevent your dishwasher from filling.
Sometimes it can happen due to float valve and on other occasions due to float
switch. Inspect the water hose coming to the dishwasher for any blockages. If the
hose is not clogged then check the water inlet valve for any clogs, if the
water will not even fill for few seconds then certainly the water inlet valve
is bad and should be replaced. You can also use a multimeter to check
continuity on inlet valve. If you don't get any value on the multimeter then
you'll need to replace the water inlet valve assembly. However, if the valve is
fine then the float switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Sep 16, 2011 | Whirlpool Dishwashers
Apr 27, 2010 | Whirlpool 24 in. GU1200XT Built-in...
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Apr 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Jul 18, 2008 | Whirlpool Dishwashers
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Feb 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Jan 31, 2021 | Whirlpool Dishwashers
Feb 13, 2019 | Whirlpool Dishwashers
88 people viewed this question
