Imei 353784040663702
SOURCE: I need your help about my Nokia N80. forgot my lockcode
Hi if the phone is asking for the code when you swtich it on then i can help you with master code but this code only works if its asking for code as soon as you switch on and will also only work if you havent entered the code wrong more than 5 times if it has been wrong more than 5 times then it can only be unlocked using flash lead and unlocking software let me know then i can assist you further ok
SOURCE: forgot my lock code for N73
you need to have a master reset code to reset all the settings. I do have an unlocker for this. if you want just give me the IMEI code and I could process it for you FREE.
SOURCE: forgot lock code
hi there,
how are you..
here i write some instruction that you can follow to unlock your phone....
hope it will help you to deal this matter.
any further question that you want to know you can log on this site for additional information.
http://gleez.com/articles/did-you-know/nokia-secret-codes
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
SOURCE: i forgot my security code for my nokia 5310 imei (352072023337804
be sure you have software of either twister or jaf. there you can create new imei.
SOURCE: orgot my security code Nokia 1100
Your IMEI: 359399009958078
Your Nokia Master Code: 6260611472
Steps to type Master Code:
1.This is master code.It has to be entered when your phone is started and asks for code..(security or master)..
2.If you type 5 times wrongly,the phone will get whole locked.. so,try 1 time.
3.If you fully typed 5 times wrongly ,you have to get a software tool to unlock and that costs greater than the phone you got..
so,try 1 time and let me know..
my email id:[email protected]
