Bosch AE-9.5 Electric PowerStar PowerStar Electric Tankless Water Heater 9 Logo
Trucker McNeal Posted on Dec 20, 2015
The internal circuit breaker keeps tripping. Have to reset every time. Where can i get a new one?
Every time i want hot water i have to turn water on and reset switch.
1 Related Answer
Anonymous
  • Posted on Mar 07, 2012
SOURCE: PowerStar AE125 seems to have failed
the circuit board is gone bad, try this, with power off reset the overload on the heater.Turn power back on and turn on water to the unit. with no taps open hold the pipe near the left element for a few minutes. it will most likely getting verry hot and trip the overload.(this is done with no water running and power on to the unit).you may even hear the water in the left elemnet start to boil or sizle. the reason for this is the triacs on the cir board are bad.I have troubleshoot this troblem many times. the design is bad and their in now a new unit (redesign) out . bosch knows their junk and wont cover them beyond 1 yr. one way around it is call tech at bosch and tell them its leaking. the u will get one of the new designs. Also applies to the AE125, Rp27pt
1helpful
Hi there... Our hot water cut out. We went into the heater and reset it, only has one reset button. The water worked for a minute and then it tripped out again. Has nothing to do with the breaker.
The unit's circuit breaker is there in case of internal faults in the uinit. The best option is to contact the dealer from whom you purchased it or the manufacturer.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
1helpful
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
2answers
The tankless water heater was working this morning, but now it seems no power is going to it. We've checked the circuit breaker several times but it doesn't seem to want to reset. Is there a fuse that...
If the circuit breaker will not reset it could be a few different things. First, circuit breakers do wear out. The bi-metal strip that makes the breaker function does break down metallurgy wise. A new one would have to be installed to fix this problem. The other possibility would be that a wire inside the water heater has grounded out thus not allowing the breaker to reset. A wire might have gotten to hot and the insulation around it might have melted or became brittle and fell off allowing the wire to touch bare metal inside the water heater.
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Hot water gets too hot trips off at tank then water gets cool and i push reset button and water gets hot again real hot thentrips off again
It's time to replace your thermostat. Instead of maintaing the correct water temperature, the water is getting so hot it is acivating the safety circuit breaker. If this breaker were to fail, you could have a devastating explosion
We have a new Rheem 30 gal short water heater. It only seems to put out about 10 gallons of hot water before it starts going cold,any suggestions......
I am assuming that everything was fine and then all of the sudden available hot water usage time dropped.
On a dual heating element hot water heater it can be
1. Internal tank loaded with sediment (drain and purge from lower garden hose fitting)
2. Thermostat or element problem with ONE of the 2 heaters. (Trouble shoot element thermostat)
3. Check Circuit breaker for partial trip of the breaker.
No hot water.
Please get an expert in - this is either the breaker is faulty or you have an electric fault int he boiler. You can try and replace the breaker - but match the current rating. But this could be dangerous if you keep trying to reset.
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
