Question about Lexmark X Office Equipment & Supplies
X7350. Why does it keep indicating left cartridge incorrect?
Installed a new one, still the same.
Posted by cliff728377 on
5 Related Answers
Anonymous
SOURCE: Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Posted on Jul 06, 2008
Anonymous
SOURCE: I have installed a black 23 print cartridge in my
Left/Right Cartidge Incorrect - huh? The printer is saying Left Cartridge Incorrect or Right Cartridge Incorrect,
and you are sure that you inserted the correct cartridge, a #23 or #24.
A small number of #23/#24 cartridges will report as Incorrect Cartridge because
of a manufacturing issue. There is a firmware upgrade available to fix this problem, and allow
the printer to accept the cartridge.
3500-4500 Series (X3550, X4550)
3400 Series (X3430)
1400 Series (Z1420)
To apply the upgrade:
  1. Make sure the printer is turned ON and connected with a USB cable.
  2. Download and run the appropriate update program using the links above.
  3. Be careful not to disconnect or turn off your printer while it is being updated.
When the update is complete the printer should automatically restart and accept the #23/#24 cartridges.
Posted on Jun 26, 2009
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
Posted on Nov 23, 2009
birky09
RiGhT - cLiCk
  • 104 Answers
SOURCE: i put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Posted on Nov 29, 2009
Anonymous
SOURCE: My printer keeps saying left cartridge incorrect.
i have a printer that says left cartage inccorect when it is not anyone have a solution for that??
Posted on Jan 17, 2010
My loptops installed new installed new operating system but theres no sound..
After the OS was installed the DRIVERS to the board and the MUSIC players can be installed. The default music player must be checked . Open the AUDIO PROPERTIES and increase the volume.
If not there are errors in the OS, the drivers or the the board. If this is a new PC please get FREE support before anything is tried.
Jul 21, 2011 | NEC Computers & Internet
Hello, I Have a new freezer. It was installed 16
the freezer will not cycle off until the desired temperature is reached.
Feb 12, 2011 | GE FUF21SVR Upright Freezer
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
The imaging unit need to be changed but it was just changed
When a new Imaging Unit is installed there is a fuse contained within the new unit that blows and resets an electronic counter in the machine. If you installed or had installed a new imaging unit, then the only way the machine would be asking for a new imaging unit now is if either you ran about 70,000 copies or somehow the new unit did not reset the counter. I have never heard of one not resetting the counter as at the same time the counter is reset, the machine initializes the new unit and adjust the ATDC ratio. If this had not occured the mixture of toner to starter (developer) would not be correct and the copies would either become light (undertoned) or have a dark background (overtoned).
If you had the new unit installed then I would contact the service company that installed it and ask for a replacment. If you installed it yourself then there may not be much you can do. You can order a new reset fuse for around $5 and replace the fuse in your imaging unit so the machine thinks there has been another unit installed. precisionroller.com has them. Just go there and enter "Di350 fuse" in the search box. In case you were not aware, Your NEC is made by Minolta and is indenticle to a Di350/351.
Those would be your options.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 17, 2010 | NEC IT3510 Copier
Installed new hard drive, now i have no sound. installed drivers, and nothing shows up missing in device manager
Usually if you have installed an new hard drive, you need to install also your laptop driver. After you've successfully installed the driver you need to restart the unit to take effect.
Apr 01, 2010 | Sony VAIO VGN-S150 Notebook
I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
TV Tuner Not Installed
use roll back driver see its work do you knew how to roll back
Aug 15, 2008 | Dell Dimension 2400 PC Desktop
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
